Results 1 to 10 of 21
Thread: Attaching stuff to cinderblock garage wall
    Jun 2010
    3,220
    Could you guys kindly tell me what kind of screws/bolts I should use to attach a ledger board (or several) to the cinderblock wall of the garage? I may want to remove them at a later date if we decide to finish the garage.
    Thanks
    AKA The Rookie
    17,475
    what are you planning on holding up there? my choice is tapcons. blue screw type fasteners that you pre drill a hole and then anchor with the screws. most do it hardwares have them.
    http://www.concretescrews.com/tapcon-questions.aspx
    You talking Cinder block or Concrete block (not the same thing) Cinder Block was from WWII era when Concrete was a scarce item and Cinders were pleantyful as most were burning coal.
    Tapcon for the Concrete blocks, Toggle bolts for the Cinder blocks as they will crumble away from the Tapcons.
    I have used them a lot lately on a job (went through about 20 boxes) simple as drilling a hole and screwing them in with a screw gun. Use a clutch to prevent stripping out or snapping off, Don't suggest an impact drill as it makes them strip (IMHO) although there are those who are successful.
    3,132
    Like Larry said go with tapcons. Make sure you hit a motar joint. Now if you no the blocks are poored solid you can put them where ever you like.
    Steve
    17,475
    bill is right on cinder block i figured you were talking concrete blocks not many cinder blocks around any more in my parts anymore
    Jun 2010
    3,220
    I call everything cinderblock. Probably not the right term. Looks like concrete blocks.....I can post a picture next week.....house was built in 1990.
    AKA The Rookie
    17,475
    if its that new they are concrete blocks..
    Jun 2010
    3,220
    I'm not planning on hanging anything. I want to attach some junky old bookcases to the wall so they don't fall over when they're filled with stuff.
    AKA The Rookie
    too bad that the bookcases can not be fasten to the ceiling or rafters
    Rio Rancho, NM
    1,417
    Quote Originally Posted by ray hampton View Post
    Why can't they? I have a very heavy crystal cabinet hanging in my kitchen from the ceiling. It was a bear getting the lag bolts up through the ceiling and into the cross-rafters (only about 14" of head/body room), but it got done, and it hasn't moved in 8 years. And it has glass doors, glass shelves, and a LOT of crystal and glassware in it.
    Nancy Laird
    dandnspecialties@msn.com
  1. Attaching The Flags
    Last Post: 07-15-2014, 06:21 PM
  2. Attaching a table top
    Last Post: 06-01-2012, 07:27 PM
  3. question about attaching raised panel sections to wall
    Last Post: 06-11-2011, 07:44 PM
  4. Help needed - attaching sign to brick wall
    By Rennie Heuer in forum Carpentry and Construction
    Last Post: 06-16-2010, 05:33 PM
  5. Attaching Workbench Top
    By Homer Faucett in forum Neander Woodworking Q&A
    Last Post: 01-11-2008, 11:47 PM
