Atlas 12 3/4" Model 53 Drill Press ***Back Together***
Greg Cook
Tokiwadai, Japan
Been a lot of activity on drill presses here lately. New Steel City Tool presses, Kermit, other old iron restores.... Here's my old iron restore candidate. I got this as a package deal; Atlas drill press, Delta scroll saw and Craftsman RAS for $35 on a local online ad. The DP belonged to the family's grandfather. There is an Atlas #53 on the Old Machinery site that states a manufacturing date of 1945.
The press is in great shape, with nothing broken or missing. It also has the cool lamp, original I would imagine. I need to find a motor for it, maybe 3/4 or 1hp? 115/240V would be nice.
Says Model #53
This is probably going to be a "little bit at a time" project, as I have to find the motor, make sure all is working (should be no problem there) and then wait till it's a bit warmer to paint. I'll mount it on a Craftsman stand with a Herc-U-lift mobile base. This won't take the place of my new SCT floor press...just for a quick drill, or maybe a sander?
Here's one restored:
Nice old press, Greg
It's in such nice shape that the restoration shouldn't be very involved. As you need to get a motor anyway, perhaps you might think of a 3 phase and a variable freq. drive. You could turn it into a low speed torque monster :)
I plugged the Pat No into Google Patent search.
See the whole patent here
Below is a technical drawing from the patent.
Thanks, Ian
I've tried to follow the conversations on 3Ph motors and various converters to go from 120VAC single to 240VAC 3ph....but it still isn't clear to me. :dunno:
Also, where are all these cheap componants people keep talking about? :huh:
The actual restore should be fairly fast...It's still cold as can be in the shop (garage), and I can't spray paint in the house...:eek:
Well, I had some time, so....
The Atlas came apart fairly easily.
The main parts broken down.
A few minutes with a wire wheel on my grinder, or just a degreaser and wiping with a clean rag does wonders... On motor mount stud and 2 handles on the right are "before".
The tube is 2 1/4" diameter...I wonder if I should get a longer tube that size and make the Atlas a floor model, or keep as a bench top...
The lamp will polish up nice. Note the thick, blue tinted lens. I'll also put a new lamp cord on it and use the original plug, as it is in perfect shape and the old style to match the DP.
Wow, what a find, Greg, and at a nice price. Are you sure it even needs paint? From here it looks like a little de-rusting on the exposed metal and Simple Green on the paint would shine it up a lot. Seems a shame to cover up the buck decal.
Although I do believe purple has more horsepower. :D
Vaughn,
I've been :huh::huh: about the paint too.... The "Buck" decal is for a company here in Seattle, so I'm going to contact them and see if I can get a "new one".
I also found out that I have the optional Hi-Lo Speed Attachment (center pulley assembly) tha will take the speed down to 200rpm and go higher than normal in a different pulley configuration.
The light looks like it was also an original option, but I haven't seen one like it in any of the other pics I have found.
I sure wish I had an original Atlas motor.... 1/2hp, 220VAC was one they had.
I like it! I like it!
And ditto the other comments, I don't think (base on what I can see in the photos) that I would paint it either.
As for cheap VFD's. It just a matter of time, hunting and watching for the deal.
Jeff
Who fried a VFD last night. :eek:
Thanks all!
OK, just a good cleaning...wax job...motor...and away we go!:thumb:
Some specs:
Drills to center of circle ...12 3/4 diameter
Chuck Capacity...1/2"
Spindle Travel...3"
Max distance table to chuck...9 3/4"
Max distance base to chuck...13 1/2"
Size of table...8" x 9"
Ground steel column...2 1/4" diameter
9 speeds between ... 600 ~ 5200 rpm
With Hi Lo Attachment...Low speed 200 rpm
Overall Height...36"
Overall Width....11"
Overall Depth with motor....24"
Shipping weight less motor...95lb (heavy!)
Motors recommended...1/3 or 1/2hp, 1740 rpm
Chuck...Jacobs, 6A 33 Taper
Ditto the others re: painting. You'll save yourself a lot of work and spare the decal. Nothing wrong with a veteran tool showing its age - and yours has aged very gracefully. Brighten up the bare iron on the table and base and any other shiny bits and you'll have a real looker :D
Greg, I did a lot of searching for consumer grade VFD's and I didn't turn up much. The Hitachi LS200 series looks nice, but it's pushing $300 bucks. And then there're displays, controllers and other stuff that's over my head.
Anyone else care to enlighten us ? Also 3 phase motors with mounting plates (C chassis ??) seem to be as scarce as hen's teeth.
Well, I did a quick clean-up on it and it's now back together. Need to find a motor and get it running. I think it turned out pretty good, compared to before.
Before pic
After
Looking very spiffy Ken ! :):thumb:
I've done some prowling for info on VFD's and motors.
The most informative answer I found is contained in a thread on an electrical engineering forum found here:
http://tinyurl.com/2c3ly9
In a nutshell, if these guys are to be believed, 110 volt induction motors are not worth the trouble (we pretty much dismissed those on here not long ago). Even on a 3 phase motor, using a VFD to reduce speed will loose you both torque and horsepower. Bottom line, replacing the sheaves (stepped pulleys) or buying a lower rpm motor are better solutions for reducing speed. Only with smaller motor pulley and/or larger spindle pulley will give you decreased speed AND increased torque.
Ian,
Thanks for the link. I'll check it out.
I found a 1/2 hp 120VAC motor that was on an old junk lathe a guy give me. I hooked it up, and .....We have take-off!!!:thumb::thumb:
Only problem is that it seems the bearings are starting to go as it starts squeeking after running for a short time....even with no load. I may take it to a motor shop and see what they think, or just look for a new/newer one.
The pulley stack in the middle of the pic is the optional Hi Lo Attachment, which allows me to get down to 200rpm. Adjusting/changing is a bit of a pain, though.
Ian,
Cool, done in record time! :clap:
Yeah, that's why it holds the patent, I guess. If you can get 200rpm as it sits, you can spare yourself the grief of hunting down a VFD. I think my Delta's minimum is 450 rpm - too fast for my circle-cutter, among other things.
You and your Atlas are good to go :D
One thing to remember is that the Atlas was basically a freeby ($10) and will be a nice spare/utility bench press/sander. My main DP will be my new Steel City floor DP, and it gets down to 215 rpm as it is.
It's been a fun project, and I learned a few things. Also got some exercise lifting and moving the hunk of cast iron....:rofl:
Greg, nice going!
Changing out motor bearings is easy as can be, especially as you have a lathe, if you need to turn a special sized tube etc to bang things back on with.
A puller puller is a good investment, if you don't have one.
Just a thought! :D
