Page 1 of 5 12345 LastLast
Results 1 to 10 of 42
Thread: Dust collection question
    17,475
    ok if you have one dust collector hooked up to existing duct work, and get a draw of some degree. if you were to hook another identical motor and impellor setup to the same duct work threw a double wye and exhaust it out threw said bags or directly outside.. would you have more draw at the machines? would it be double the draw or not???
    Nov 2007
    Salt Spring Island, BC Canada
    2,070
    If you are matching HP to HP I don't think it would make any difference. Only give you more collection capacity.
    17,475
    thats what i am thinking drew, if i had two hooked up to the same lines i should get double the draw..but i am not a hvac guy and definitely not the brightest penny in the can
    5,323
    I think you'd end up being limited by the capacity of the ductwork - both volume and velocity-wise.
    Might be better to just split the ducting and use different DCs for different tools.
    That's just my guess, though. I have no experiences to back it up.
    NH
    4,012
    Just my 2 cents
    If they both draw 5 cfm than would it not make scents that there would be a 10 cfm draw at the pipe?
    That is as long as the pipe could handle the air volume.
    Stupid hurts.
    5,323
    Just my 2 cents
    If they both draw 5 cfm than would it not make scents that there would be a 10 cfm draw at the pipe?...
    Or would the two DCs somewhat fight with one another?
    17,475
    that is how i see it chuck i know you cant only draw so much threw a small hole but if i a vacuum sweeper was hooked to it it would be alot less draw than a real dc motor and impeller
    NH
    4,012
    I think they would pull from the path of least resistance.
    Stupid hurts.
    17,475
    wheres our resident physicists? for some mathematical theory to answer this dilemma?
    Nov 2007
    2,070
    I sort of look at it as a stream ( I always think air flow as similar to that of water) if you have two eaqual drops spitting the stream you don't get a bigger flow just less volume. It's a simplistic approch but I think it sounds valid.
  1. DUST collection question????
    Last Post: 11-23-2012, 06:51 AM
  2. GRR-Ripper question--dust collection???
    By Ron Jones in forum General Woodworking Q&A
    Last Post: 03-31-2011, 03:54 AM
  3. Question on size of Dust collection System
    By Dom DiCara in forum General Woodworking Q&A
    Last Post: 09-26-2010, 02:52 AM
  4. O/H dust collection arm...updated question!
    By Jim O'Dell in forum Jigs and Fixtures
    Last Post: 11-18-2007, 12:00 AM
Tags for this Thread
