Results 1 to 2 of 2
Thread: GSU Miter Cuts
    Charlotte, NC
    1,487
    GSU Miter Cuts
    I am trying to make some moulding in GSU. How do I make a miter cut in this?
    Thanks for any suggestions.
    SE Minnesota
    2,550
    Ed, this is a job for the "Cutting Plane"! Da da da daaahh!. Sorry. No coffee yet this morning.
    Actually a cutting plane is just the ticket for this. You draw a plane that cuts through the molding at the desired angle. Select it and the molding. Right click and choose Intersect and then choose Intersect selected (I'm assuming you have GSU 6 other wise just choose Intersect with model.) Delete the waste and the part of the cutting plane you no longer need.
    Use Guides (aka Construction Lines) place with the aid of the Protractor tool and Tape Measure tool to give you the correct angle and placement.
    Hope that helps.
  1. Some more assembled off-cuts.
    Last Post: 07-12-2012, 07:09 PM
  2. My cuts are off a bit
    By Bob Gibson in forum Carpentry and Construction
    Last Post: 01-19-2010, 03:59 AM
  3. Makita LS1040F 10" miter saw. Inaccurate cuts
    By Craig Johnson in forum New Tools
    Last Post: 02-13-2009, 08:48 PM
  4. G0513X, First Cuts
    Last Post: 10-09-2007, 05:52 PM
  5. Five cuts to square you CMS
    By Stuart Ablett in forum Jigs and Fixtures
    Last Post: 04-12-2007, 02:15 PM
