Results 1 to 10 of 11
Thread: Renaissance wax question
    Palm Springs, Ca
    1,169
    I have been using Renaissance wax on alot of the turnings and I read a article on AAW where someone stated the best way to use it is to put it on by hand scrubbing it in with a rag or paper towel............let it sit for a hr and then buff it off with a cotton wheel at low speed.......the person said that it would produce the best shine that way...........anybody else using it this way ?
    Low speed ?............like what?.......800 or lower ?
    I pm the person and never did get a answer but thought I would post on here and see how others are using it...................
    I have been using it on some of the projects that i finished with laquer............let dry for a week or better......knocked down with 0000 then applied it by hand and removed it by hand both............would there really be that big of a difference..............
    30,014
    After a piece has been buffed with the other compounds, I apply a thin coat of Renaissance wax by hand (I use a little 2" or so square of t-shirt material), let that dry for a while (5 to 30 minutes, give or take), then buff with a clean flannel (cotton) wheel spinning between about 800 and 1200 rpm. I use a light touch and relatively low speed to avoid melting (and removing) the wax.
    Tellico Plains, Tennessee
    4,351
    I've never used the Ren wax, but see that lots of turners do... I guess I need to try it sometime. Until then only answer I have is
    Chuck
    Tellico Plains, TN
    Goodland, Kansas
    4,834
    I started using it because I didn't like finger prints or water spots on my pieces. I apply it by hand with a soft paper towel or T-shirt. I leave it for 2 to 5 minutes then buff. They say it dries instantly.
    Bernie W.
    After buffing with appropriate compounds I apply ren/wax by hand real skin then buff it off with a light touch to the cotton wheel.
    Remember the tea kettle - it is always up to its neck in hot water, yet it
    still sings!
    Palm Springs, Ca
    1,169
    Well thanks for the responses.......I have been doing it either by hand or on a buffer i have with a speed or 1250.....very light touch is right.......have also buffed by hand...........just depends i guess.....but thanks for the responses
    I remember when Eli Avisera was here doing a Demo he said that anything you put on a piece on the lathe should be applied with the lathe turned off, his main reason for this was the the spinning piece would fling the finish out from the piece. I guess this would only apply to the outside of a bowl
    The other reason he said was safety, which in my opinion is even more important, spinning wood, finish and fingers combined could result in a trip to the hospital
    BTW, I've been told that the clear shoe polish, the Kiwi stuff, is basically the same as the Renaissance wax
    I know it sure smells the same, and it costs a TON less, and if it works for shoes FYI
    13,360
    I was going to say that the Ren Wax does have a distinctive odor. Never smelled the clear Kiwi wax, but I doubt it has the same insert describing all of the various benefits and applications!
    Just bought a can of the Ren wax a little while ago. Guess next time I stop by Wally World I'll have to take a look for some kiwi!
    30,014
    The other reason he said was safety, which in my opinion is even more important, spinning wood, finish and fingers combined could result in a trip to the hospital ...
    I do nearly all my finishing off the lathe, but I'm guessing Eli doesn't use a lot of friction polish like Myland's. Although I wouldn'[t use it on a bowl of other large piece, it's handy stuff for smaller things that don't need a super durable finish.
    Aug 2008
    Reno, Nv
    3,632
    Years ago, I used to use both Ren wax and Mylands on pens...then I was schooled by finishes that wore off. On boxes they both work well. I adopted an approach that Richard Raffin did on a video. He wiped a piece of 0000 steel wool in renwax and applied it at about 800 rpm. It looks really cool!
  1. Renaissance V. Kiwi wax
    By Dan Mosley in forum Lathe Project Showcase
    Last Post: 08-20-2010, 02:36 AM
  2. Renaissance Waz
    By John D. Frigillana Jr. in forum General Woodturning Q&A
    Last Post: 09-25-2009, 08:52 PM
  3. Renaissance Wax: Best way to apply?
    By Keith Palmer in forum General Woodturning Q&A
    Last Post: 12-13-2008, 02:21 AM
  4. Part 1: (of 4) About Medieval and Renaissance Lathes
    By Don Taylor in forum General Woodworking Q&A
    Last Post: 02-24-2007, 12:18 AM
