Page 1 of 5 12345 LastLast
Results 1 to 10 of 43
Thread: Anybody here have experience in automotive electrical issues?
    13,357
    The ole pathfinder has some kind of weird electrical problem.
    New battery, alternator seems to be generating a decent charging voltage around 14+ volts. It starts fine and runs good, but some of the accessories just don't work right. The dash voltmeter reads lower than my voltmeter on the battery. Put on the turn signals and the voltmeter bounces in time to the flashes. Turn on the headlights and the relays on the fuse box buzz and the whole electrical system goes crazy. Same with windows.
    Going to run some more tests later to see if I can narrow things down.
    Very frustrating in this heat to not be able to roll the windows down...
    Jul 2007
    DSM, IA
    5,719
    Did you kick it? Sorry, that's about all the help I can give.
    My Website
    Brent,
    I had a similar problem with an S-10 I had once. Turns out the ground where it went through the firewall was corroded. I ran a new Ground wire from the battery to the dash and the problem went away.
    17,470
    a bad ground was my choice as well brent am not a mechanic guru but from what i have dealt with it sounds like a ground problem.
    13,437
    Bad ground here too...definitely
    edit...could be power cable to that area (or connection at power block), but most likely ground
    13,357
    Thanks guys. Seems like the thing to check. I've got all the schematics, now if I can just find out where the fuse block gets it's ground, I'll give that a shot.
    Funny thing is I've got a post on the nissan forums about this and not one suggestion. 1 hour here and look at all the help I got. And this forum isn't even about cars
    17,470
    its like politicians brent they spout off about things they have no clue on like real jobs or work ethics
    5,319
    Check also the ground between engine and chassis. The battery to chassis (negative cable) may be corroded at the chassis, also.
    Good luck. This kind of problem is often a bear to solve. (Sixteen years experience as an aircraft electrical technician - DAMHIKT)
    Indianapolis area
    1,697
    +1 on a bad ground someplace. May be difficult to find. Start with the obvious options first.
    ________
    Ron
    "Individual commitment to a group effort--that is what makes a team work, a company work, a society work, a civilization work."
    Vince Lombardi
    I would just run a seperate ground from the batter and be done with it.
  1. Hand Carved Engines and other Automotive Art
    By David Agnew in forum General Woodworking Q&A
    Last Post: 01-25-2013, 07:34 PM
  2. Electrical Done(?)
    By glenn bradley in forum Carpentry and Construction
    Last Post: 10-14-2007, 09:31 PM
  3. Automotive Trivia Question
    By Dave Richards in forum Off Topic Discussion
    Last Post: 06-18-2007, 03:00 PM
