Results 1 to 6 of 6
Thread: Pepper tree blanks follow up
    Palm Springs, Ca
    1,169
    Picture 1 - Took the roughed out pepper tree vessel out of soak this morning and let it air dry for several hours -Then remounted on the lathe for sanding. I sanded thru 400 and put in the soak of oil.......more later
    Picture 2 - Next I decided to turn some Ironwood and wanted to cut it so the end grain was outward. I used a home made sled type to take off a slice so I could cut it in that orientation.
    Picture 3 - Sliced and then cut down the middle - then rounded and taken to the lathe
    Picture 4 - Rough turned hollow form from the cutting
    Picture 5 - came out blurry but it was another one of the ironwood blanks - soaked for 24hrs in oil bath, dried for a day and 1 coat of DO applied.....now drying out inside to avoid the checking.......so far so good....................
    Attached Thumbnails Attached Thumbnails First-Cut-1.jpg   First-Cut-2.jpg   First-Cut-3.jpg   Small Hollow-2.jpg   Small Hollow-3.jpg
    Looking good Dan, pretty wood!
    Goodland, Kansas
    4,834
    Looks good Dan.
    Bernie W.
    Jul 2007
    Des Moines, IA
    854
    Really nice Dan. Keep them coming.
    Aug 2008
    Reno, Nv
    3,632
    That is some cool wood!
    Palm Springs, Ca
    1,169
    Thanks to everyone.................
  1. What path to follow???
    Last Post: 02-02-2012, 11:03 AM
  2. Log cutting - Pepper Tree Trunk
    Last Post: 07-08-2010, 03:45 AM
  3. Going big follow up
    Last Post: 05-05-2009, 03:13 AM
  4. Pepper and Salt and Pepper Mills
    Last Post: 12-25-2008, 05:46 AM
  5. Smaller tree limbs for blanks?
    By Jim Zimm in forum General Woodturning Q&A
    Last Post: 05-20-2008, 11:54 AM
