Results 1 to 7 of 7
Thread: Speaking of crosses
    Southeast Pa
    2,019
    Speaking of crosses
    I have a question about the ratio for a Cross. I have looked and not really found anything. Is there a standard for the length of the cross piece to the vertical? And where is the cross piece mounted on the vertical.
    I have made a few in the past and always just used what looked good to me....
    Thanks
    Garry
    Constantine, MI
    7,888
    The base point to start from is a 1-2-3 ratio. Simple example: If the cross arm is 2' wide the the vertical above the arm is 1' tall and the vertical below the arm is 3' long. IMHO
    www.wrworkshop.com
    11,825
    I used the eyeball factor.
    "uh...lemme see....that looks 'bout right....."
    We've all got a cross to bear, for you, it is figuring out what works best... Rennie has a good point as well as Frank.
    2:1 for the vertical vs the horrizontal is correct, as far as the top to bottom, I go by whatever looks right.
    [QUOTE=Garry Foster;227342]I have a question about the ratio for a Cross. I have looked and not really found anything. Is there a standard for the length of the cross piece to the vertical? And where is the cross piece mounted on the vertical.
    Thanks
    Garry[/QUOTE
    Try this
    Freedom is just a word for nothing left to lose
    Southeast Pa
    2,019
    Just wanted to thank all those that responded. It gives me a lot of more accurate information than I had before.
    Thanks again..
    Garry
  1. Speaking of Old...
    By Ted Calver in forum Off Topic Discussion
    Last Post: 08-10-2014, 12:35 PM
  2. Speaking of Cleats
    Last Post: 11-24-2011, 02:37 PM
  3. Alphabetically Speaking....
    Last Post: 09-17-2011, 10:10 AM
  4. Speaking of boxes
    By Terry Quiram in forum Lathe Project Showcase
    Last Post: 02-26-2009, 08:43 PM
  5. speaking of reverse......
    Last Post: 07-20-2008, 04:20 PM
