Results 1 to 10 of 15
Thread: A little help from my friends?
    5,172
    I need to talk with and electrical/electronic guru. Anybody?
    That is a big field Carol, some details would help
    12,251
    I would add to that its my stock trade but its a vast field.
    5,172
    I want to know how to build - from scratch - a battery charger. Simple. No feed back circuits. From 110v AC to 12V DC 6 amps.
    Yes, a stepdown transformer and a rectifier, but I need more specifics than that.
    It is hard to ask the right questions when I know so little as well.
    12,251
    Carol is there a very specific reason why? I mean if you were embarking on building electronic ciruits for a hobby as i did before i went into the field then it would be like all of us and woodworking you dont really care about the economics you do it for the pleasure and fun.
    But battery charges are so cheap today that i doubt you gonna do it for less and then you need to think about the extras and the type of technology of battery you wish to charge.
    These devices have come a long way from being just a transformer with a rectifier as we have learnt over time how to look after a battery and the different battery technologies.
    What do you wish to use it for. Battery type, ampere hour rating etc.
    There are many issues involved. I dont want to rattle on here and cover them all it would depend on the battery technology and use.
    My recommendation though would be to urge you to buy before you build unless this is a very specific requirement that you aint seen a charger off the shelf for.
    5,172
    The point is not to charge a battery. It will be used to fire a wood burner pen.
    So no smart technology which is where battery chargers are today.
    For continued wood burning, especially when branding, an ordinary wood burning pen is far too wimpy. This circuit is further tempered with a dimmer switch to control the "temperature" of the pen.
    The Silicon Woodturners club has an article in their newsletter archives where a member did use a manual charger to make one of these.
    The problem is manual chargers are very hard to find. NAPA does make one but it is $90.
    I did find a circuit on-line but I don't know how to evaluate it.
    13,442
    There are a couple of the manual chargers at harbor freight for about $29 - $39...
    http://www.harborfreight.com/2-6-amp...ger-45005.html
    http://www.harborfreight.com/10-2-55...ter-66783.html
    Southeast Pa
    2,019
    Carol that circuit should work fine...however I'd probably start with a battery charger even one from harbor freight, or a used one from Ebay unless you already have a transformer..
    Garry
    Garry
    Bellingham
    2,449
    Both of these automatically switch to a trickle charge, so they not be considered "manual", would they?
    Southeast Pa
    2,019
    Carol
    A little more research shows that the diodes and capacitor are unneeded. All that is need is a high current low voltage source. It a resistive heating unit that could care less if its feed AC or DC. In actual use probably less than three volts at 2-6 amps. The battery powered soldering irons I used at work ran off of 3 volts....
    Back in the 60's we made soldering guns in shop class buy stripping the secondary off a transformer and placing a one turn secondary made out of a strap. Then feeding a normal soldering gun tip. Or making our own tip out of about 5 inches of #12 wire..
    So to go simple hoop your dimmer up to the input of a 6 volt (not critical) 4 amp or so transformer and the secondary to your burning pen/element..
    For other ides look at "Foam Cutters" as they are basically the same thing. And there is a little more info floating around the net for these things..
    Garry
    Here is a "sketch of a circuit that would work...safety is up to you..!
    http://members.fortunecity.co.uk/slm..._Cutter_PS.gif
  1. THANK YOU MY FRIENDS
    By Jonathan Shively in forum Off Topic Discussion
    Last Post: 12-12-2013, 04:06 PM
  2. for my friends
    Last Post: 10-23-2013, 06:09 PM
  3. Say hello to my little friends!
    By Jim Burr in forum The Cook Shack
    Last Post: 08-07-2013, 01:10 AM
  4. hello old friends
    Last Post: 05-28-2013, 01:20 PM
  5. Old friends...
    By Greg Cook in forum Off Topic Discussion
    Last Post: 07-24-2007, 02:22 AM
