Results 1 to 1 of 1
Thread: celtic knot and blank cutting jig for sierra pen
    Dec 2008
    falcon heights, minnesota
    5,609
    had a little bit of time today, so i made up 2 of the 3 jigs i needed. the first is the blank cutting jig for sierra pens, i wanted to be more consistant in cutting blanks. the second is a jig for doing up celtic knots in sierra pens. after getting a couple done, i found that 30 degrees looked best. the jig is similar to the first one, but i measured how far down the blanks i wanted the knot to be, and glued a stop block there. the cut on the first jig is 90 degrees, and the second is at 30 degrees. now i can be more consistant in placement and width of the celtic knots.
    Attached Thumbnails Attached Thumbnails sierra blank cutting jig.JPG   sierra celtic knot jig.JPG   sierra celtic knot angle.JPG
    benedictione omnes bene
    www.burroviejowoodworking.com
  1. A few Celtic Knot pen blanks
    By Terry Quiram in forum General Woodturning Q&A
    Last Post: 03-29-2014, 05:36 PM
  2. Celtic Knot Longwood
    Last Post: 03-31-2011, 02:00 AM
  3. First try at a Celtic Knot
    By Mason Kuettel in forum Lathe Project Showcase
    Last Post: 02-24-2011, 03:19 AM
  4. Bloodwood with celtic knot
    By Jonathan Shively in forum Lathe Project Showcase
    Last Post: 10-29-2007, 02:56 PM
  5. Wrong way to do a celtic knot
    By Curt Fuller in forum Lathe Project Showcase
    Last Post: 02-25-2007, 03:16 AM
