Results 1 to 5 of 5
Thread: Milling Corian countertops
    Sep 2007
    Plainwell, Michigan
    4,857
    I have to do some custom work on some corian counter top material, how well does this stuff cut? Need any special blades for a bandsaw to cut? How about router bits, anything special to use?
    Thanks in advance
    Independence, Kentucky
    1,355
    Corion
    Tom Corian works well , use regular sharp carbide blades and router bits and you will have no trouble at all. It is a plastic so your bandsaw will do just fine
    Chuck
    Villa Park, CA
    1,407
    I agree with Charles. I'll add that it creates a lot of dust and swarf.
    Mike
    Ancora imparo
    2,784
    I've used a triple chip grind blade made for plastics and laminate on my saw cutting Corian with no problems. Ditto on the carbide router bits. Works great. Jim.
    Coolmeadow Setters...
    Exclusively Irish!
    Sep 2007
    Plainwell, Michigan
    4,857
    Awesome guys, thanks for the info that is what I thought, but me thinking can be dangerous
  1. Corian is Nasty
    Last Post: 01-09-2014, 11:36 PM
  2. Left over corian
    Last Post: 07-10-2011, 05:37 PM
  3. Wood countertops, how to?
    By Brian Altop in forum General Woodworking Q&A
    Last Post: 04-23-2011, 02:39 AM
  4. Working Corian?
    By Joseph Shaul in forum General Woodworking Q&A
    Last Post: 06-20-2010, 01:03 PM
  5. Shop Countertops
    By Tommy Squires in forum Carpentry and Construction
    Last Post: 05-28-2007, 04:01 PM
