Results 1 to 4 of 4
Thread: Stud wall screws
    Jun 2007
    New Jersey
    75
    Question Stud wall screws
    I'm putting up a stud wall in my attic using 2 x 4's. I plan to use screws instead of nails, what size screws should I use?
    Thanks
    Dennis
    17,472
    2.5 to 3"
    NH
    4,005
    If screwing through the plate into the stud #9-3 1/8"
    If screwing to the side #8-2 3/4"
    I would use these http://www.grkfasteners.com/en/R4_1_2_information.htm
    Stupid hurts.
    Jun 2010
    Croton, Ohio (about a half hour NE of Columbus)
    154
    I would use a deck type screw (stay away from drywall screws, they can be quite weak) at least as long as the typical framing nail used for this application. That would normaly be a 16d nail which is 3 1/2" long. I'm not in the habit of recommending screws for framing over nails at all because although screws have a much better holding force due to torque they are also much more brittle because they are typically harder steel and therefore don't have near the sheer strength of a nail. In the case of a stud partition wall you're not going to be overly concerned with sheer so screws should work fine.
  1. drawing stud walls
    By Dave Willis in forum Designs, Plans and Sketches
    Last Post: 04-18-2016, 08:03 PM
  2. Stud finders
    By Jonathan Shively in forum New Tools
    Last Post: 09-10-2014, 07:14 PM
  3. Stud finder
    By Dan Mooney in forum New Tools
    Last Post: 03-28-2014, 03:02 AM
  4. It's a BOY! It's a STUD! It's a GRIZZLY!
    By Al Launier in forum General Woodworking Q&A
    Last Post: 12-31-2012, 12:35 AM
  5. Zircon And Other Stud Finders
    By Boyd Gathwright in forum Carpentry and Construction
    Last Post: 01-19-2007, 09:34 PM
