Results 1 to 6 of 6
Thread: Keeping wood wet
    Aug 2008
    Reno, Nv
    3,632
    Keeping wood wet
    I was turning a bowl out of some really old, really curly, powder dry redwood. There were no curlies flying around, just powder so I guessing a moisture content of 2-3%. Since the Thompson 3/8" V-gouge hadn't been used yet, it was extremely sharp, I discounted dull tools. I was wondering if a spray bottle applied sparingly would help put enough moisture back into the blank...not warping it I hope, but allowing smoother turning. Still had some good sized tear-out on the inside despite fresh really sharp tool. Finished thickness is 1/8", 9"x4", recessed foot and 4 coats of rattle can laquer. Thoughts and suggestions are needed!
    11,833
    On some of the woodturning videos the experts do that occasionally.
    Shouldn't hurt.
    The bowl looks great from here, Jim.
    The water in a spray bottle trick does help, and I've never had it cause problems with warping. You can also use a bit of finish, wiped or sprayed on...lacquer, shellac, poly, BLO...whatever you're going to use for your final finish. It helps lubricate the wood and helps make the cut easier.
    You picked a difficult wood to cut cleanly. Even with sharp tools and good techniques there's a good chance for tearout. Also, the Thompson gouge was sharp I'm sure, but Doug doesn't really get them extremely sharp. He uses a 46 grit wheel (or something in that range) to put the initial shape on them, so your 120 grit (or similar) grinding stone will put a finer edge on it.
    Jul 2007
    Des Moines, IA
    854
    I have used a sanding sealer on both hard and punky wood to help with tear out. Haven't tried the water and spray bottle.
    Palm Springs, Ca
    1,169
    I have tried a few spray things and what works well for me was 50/50 water and liquid dishwashing soap.............works great...........
    I have tried other things including soaking in different things and works equally as well but the spray I mentioned is fast and easy to use....
    Aug 2008
    Reno, Nv
    3,632
    Thanks guys...I have a few more pieces and want to give them their best chance. It really is beautiful stuff, just a pain to deal with
  1. keeping busy
    Last Post: 08-28-2015, 08:12 AM
  2. keeping busy
    By allen levine in forum Carpentry and Construction
    Last Post: 07-13-2011, 03:33 AM
  3. Tree down, wood orange, worth keeping?
    By Robert Schaubhut in forum General Woodworking Q&A
    Last Post: 09-26-2008, 12:59 PM
  4. Hey Ken Fitzgerald - Keeping dry?
    By Rennie Heuer in forum Off Topic Discussion
    Last Post: 05-24-2008, 08:56 PM
  5. Keeping cool
    Last Post: 02-12-2007, 01:25 PM
