Results 1 to 10 of 18
Thread: Cracked Ash Hollow Form
    30,015
    This is a hollow form I made from another piece of my ash firewood. The blank had some cracks, but I thought I'd see if I could turn the cracks away. Ends up, I couldn't. Still think it came out pretty neat. It's 12 1/2" wide and 8 1/2" tall. I sold my biggest HF at the last show, so I wanted another big one to replace it in the display. It's finished with a single coat of polymerized tung oil, then rubbed out by hand with white synthetic steel wool and waxed with Renaissance wax. I decided to go for a little foot on this one...it's about 1 1/2" wide.
Name:	HF059 - 15  800.jpg
ID:	47390 Click image for larger version.
Name:	HF059 - 13  800.jpg
ID:	47391 Click image for larger version.
Name:	HF059 - 16  800.jpg
ID:	47392 Click image for larger version.
Name:	HF059 - 18  800.jpg
ID:	47393 Click image for larger version.
Name:	HF059 - 14  800.jpg
    And if you want to see a mess of progress pics, I put them up on my blog here:
    http://workingwoods.com/blog/wordpre...3/cracked-ash/
    Comments, questions, catcalls and kudos are all welcome.
    One very cool piece for sure, I bet a lot of people will look at it and wonder how it did survive the ride
    Looks like there might have been some stress in the wood, or wind shake etc, glad it all held together for you, hope you sell it straight away!
    30,015
    Thanks, Stu. Yeah, it kinda looked like wind shake of some sort to me, too, but not all of it was following the growth rings, so I'm not sure.Maybe some of the timber experts here can chime in and educate me.
    Jul 2007
    DSM, IA
    5,719
    Very nice Vaughn! It looks like it must be very light with all the cracks and holes.
    My Website
    12,256
    Wow and here i am messing with little knobs. Very nice.
    I like the blog. Did not know you had started it. Great move.
    When i look at the sequence of production i realize you sure got an eye for seeing something in that wood.
    Now question I have is what makes you choose a spur center over the base plate in this case. Any criteria you use to decide which to go for.
    Goodland, Kansas
    4,834
    Really nice piece Vaughn. Those kind of pieces always for me anyway increase the pucker power. Really well done. Could be wind shake but really doesn't appear like it to me.
    Bernie W.
    Apr 2009
    Red Deer, Alberta, Canada
    1,083
    Great looking form Vaughn!
    The cracks give the piece character and uniqueness and will be a great
    conversation piece.
    Well done.
    Les
    Innovation is the process that renews something that already exists and not, as is commonly assumed, the introduction of something new.
    Los Angeles, CA
    2,668
    My wife would say that it is broken but I think it has so much character.
    30,015
    Thanks for the comments, guys.
    ...It looks like it must be very light with all the cracks and holes.
    It's intentionally a bit bottom heavy. I got things a little thinner than planned at the neck and collar (about 3/16" or so, but the body walls are about 1/4" to 3/8" thick. I left some extra thickness at the foot (I'm guessing about an inch) for the weight. With its little foot, I think this one will be the first on the floor in an earthquake.
    ...Now question I have is what makes you choose a spur center over the base plate in this case. Any criteria you use to decide which to go for.
    If I'm planning on a hollow form, I like the smaller hole the spur center makes. If I had used my smallest faceplate, I'd have a 2 1/2" to 3" hole. When I started on this piece of wood I was unsure if it would be a bowl or a hollow form until I got some of it turned away. Since I was undecided, the spur center left both options open for me. I ended up hollowing this one through a 1 1/4" hole (enlarged to 1 1/2" with the final cuts and sanding).
    Quote Originally Posted by Mohammad Madha View Post
    My wife would say that it is broken ...
    Maybe that's because she's been led into believing a person is supposed to use glue when making a hollow form. I prefer to think of it as well-ventilated instead of broken. (Tell her Hi from me, BTW.)
    Oct 2007
    Harvey, Michigan
    687
    Very nice work Vaughn! I really like the heart shaped form! Looks very balanced!
    Bet this one made some noise while turning! Good job on keeping it all together! Hope it sells quickly - so you can turn another!
    Steve
  1. Cracked and Warped Holly Form
    Last Post: 02-07-2011, 03:41 PM
  2. How long does it take to hollow out a small hollow form?
    By Mike Hirsch in forum Turning Tool Questions and Show & Tell
    Last Post: 04-04-2008, 07:47 PM
  3. SW hollow form
    By Jim Ketron in forum Lathe Project Showcase
    Last Post: 01-12-2008, 08:53 PM
  4. Hollow Form #5
    Last Post: 11-30-2007, 12:24 PM
  5. A hollow form that's not a hollow form!
    By Bernie Parmenter in forum Lathe Project Showcase
    Last Post: 05-09-2007, 05:28 PM
