Results 1 to 10 of 16
Thread: drill press dust collection
    Central PA
    638
    I am moving my dust cyclone to a different part of the shop so while i'm moving the ducting around I want to add some DC to the drill press. What type of setup do you guys use. I suppose that some loc-line would work nicely but wanted to see some cheaper, I mean less expensive, solutions. Pictures are great.
    May 2009
    Lafayette, Indiana
    2,380
    This is my DC set up. Not quite what you had in mind I know.. So I will be watching this thread to get ideas as well.
    Tom
    5,172
    Here is my favorite duster.
    I don't catch dust. I chase it away!
    Central PA
    638
    I have used those options, they are alright but not quite what I was looking for.
    The shop vac does better at the DP than the DC in my testing but, either way; http://familywoodworking.org/forums/...ad.php?t=10717
    Indianapolis area
    1,697
    I have used Tom's system and Carol's system--both are workable. Think I'll look into Glenn's system.
    ________
    Ron
    "Individual commitment to a group effort--that is what makes a team work, a company work, a society work, a civilization work."
    Vince Lombardi
    Central PA
    638
    I have seen loc-line which is similar to Glenn's solution. It is the blue and orange, Its used a lot for coolant in cnc and milling operations. It comes in 2.5" size for dust collection. I don't know if its sold locally around here so I think I'm going to make something. I came up with an idea to make an articulating arm out of 2" PVC pipe. I think this will give me much better flow than locline. I used a similar concept for the blade guard on the sawstop. I did a test with 2" PVC vs. shop vac hose and the PVC had much better flow than the hose. I think this is due to PVC being very smooth and the vac hose is very rough.
    Central PA
    638
    I got something together and I think it will work great. I used 2" PVC pipe, some 90s and a few unions. I will have to take some pics when I get it mounted, the pipe comes down the wall, there is a union and a 90 then a union, then pipe and a 90, a union, a 90 then pipe. The unions work as pivot points. I stuck the "wall pipe" in the vise and the whole assembly moves really nicely.
    Jun 2007
    4,944
    My 2 cents
    Hi,
    I found that using 2.5" duct was more efficient than 4" at the DP table (ditto for the BS). The velocity of the moving air was greater so the air picked up the sawdust further away with 2.5 than 4.0. The 2.5 in is a few inches long. It goes directly into 4 in. The 4 in goes directly up to the 6 in at ceiling height.
    I am using a similar set-up on the woodlathe. It has reduced the amount of wood snow that clings to my clothes and piles up on the floor.
    Enjoy,
    Jim
    VOTING MEMBER
    Central PA
    638
    heres some pics, it works well, moves easily and stays in place. I think I will make some nozzles for it to use for different applications.
    Attached Thumbnails Attached Thumbnails Jul31_0001.jpg   Jul31_0002.jpg   Jul31_0003.jpg   Jul31_0004.jpg   Jul31_0005.jpg
  1. i-Box Dust Collection
    Last Post: 10-31-2013, 03:40 AM
  2. Dust Collection
    By Robert Delhommer in forum General Woodworking Q&A
    Last Post: 02-08-2012, 02:35 PM
  3. Dust Collection
    By Ron Roase in forum General Woodworking Q&A
    Last Post: 08-13-2011, 08:19 PM
  4. dust collection
    By gary doby in forum General Woodturning Q&A
    Last Post: 04-25-2009, 08:54 PM
  5. dust collection
    By J W Seals in forum General Woodworking Q&A
    Last Post: 10-31-2008, 03:12 PM
