Results 1 to 10 of 14
Thread: Which Came First The Cabinet Or The Floor?
    Monroeville, IN(Fort Wayne)
    111
    We are finishing our basement and putting in an engineered hardwood floor, that is tongue & grooved, glued together, but floats on top of concrete slab.
    The cabinet guy tells me to put the floor in AFTER he builds the 2X4 wall and installs the bar, but the framer that helped me get ready for drywall says to put the floor down BEFORE the cabinets.
    Who's right, or what is the recommended way
    my goal in life is to be as good a person as my kids think i am
    life is short, even in it's longest days
    2,784
    I would say the floor first, but just because it's hard to pour a concrete floor with the cabinets already there...I mean how do you hold them up for the concrete to go underneath them??
    Ok funny stuff aside. The cabinets first, then the flooring. Now for the reason: The floor is supposed to float. If it is anchored down by the cabinets, it can't float properly. Leave your 1/4" gap between the flooring and the cabinet, and cover the gap up with trim. All will be good. Jim.
    Coolmeadow Setters...
    Exclusively Irish!
    Quote Originally Posted by Jim O'Dell View Post
    +1 for cabenates first
    17,470
    +2 for jims advice.. even goes for vinly flooring.
    Southern Louisiana
    947
    cabinets first, why would you wanna spend all that money on flooring you won't see. plus because it isn't secured to the subfloor i wouldn't want to put cabinets on top.
    my thoughts
    chris
    For a floating floor you need to install the cabinets first. Just don't forget to shim the cabinets up the thickness your flooring is otherwise you could have trouble fitting any appliances under a counter top.
    Sep 2007
    Plainwell, Michigan
    4,855
    Great and timely question Kevin I hope you don't mind but I have to add to the question...........How about when using solid hard wood flooring? Any different than with a floating floor?
    Quote Originally Posted by Kevin Brown View Post
    I agree with most....cabs first
    Quote Originally Posted by Tom Niemi View Post
    Tom,
    Same for hardwood but leave 1/4" on the flooring and cover with moulding.
    Jun 2010
    3,220
    I was just about to ask a similar question. I want to put built-ins in a closet where there is carpet that will be changed--eventually. So should I put the built-ins on the current carpet, then when it's changed they will only be able to cut away the part up to the base molding? or should I remove the carpet under the built-ins and put them just on the sub-floor? (leaving the rest of the carpet until we change it.)
    THANKS
    AKA The Rookie
  1. RV floor
    By Chuck Thoits in forum Carpentry and Construction
    Last Post: 07-16-2014, 01:46 PM
  2. Four on the floor
    By Jim C Bradley in forum General Woodworking Q&A
    Last Post: 04-26-2013, 02:27 AM
  3. Heavy Cabinet, Tile Floor, Your Choice of Feet?
    Last Post: 03-02-2013, 03:34 PM
  4. To floor or not to floor.....?
    By Stuart Ablett in forum Carpentry and Construction
    Last Post: 01-10-2011, 05:52 PM
  5. First floor
    By Al killian in forum Carpentry and Construction
    Last Post: 08-08-2009, 04:44 PM
