Results 1 to 5 of 5
Thread: ROUSSEAU base plate warped
    Tampa
    281
    I bought the ROUSSEAU deluxe base plate. After installing and leveling with the included platic screws I can feel that the center of the plate is higher. Even with the router installed (Hitachi m12v) the plate is still high in the center.
    I already drilled for the router so I dont suspect I can take it back. I hope this is something that goes away.
    Anyone have this problem and does it go away?
    30,225
    From what I've read, the Rousseau plates are intentionally designed with a crown in the center. If I recall correctly, there's some discussion of it in the reviews of that plate on Amazon.
    Sacramento, CA
    1,367
    Yep - that "Crown" is by design. Their intention is well founded, but in practice I've found it a little annoying at times. I don't like my stock rocking around while on the table, but it doesn't usually cause me much harm. I just have to remember that there's a crown.
    I can't say i find it to be that big of an advantage. The idea is that your stock should ride on the crown and therefore always have a consistent depth. I can't say I notice any improvements, and had I paid closer attention to the packaging, I wouldn't have gotten it. It isn't bad, I just don't think it's really a worthwhile change. Flat always worked in the past, for me.
    Jason Beam
    Sacramento, CA
    15,811
    I've got the same plate, and I've gotten great usage out of it, but there is a trick to taking most of the crown out of it.
    Here is what I did, and it worked for me, you mileage may vary!
    Put the router on the plate, don't tighten the screws that hold the router to the plate all the way down, make them snug.
    Put the plate in the table, make sure all the sides are level with the sides of the table, then just loosen the screws holding the plate 1/2 a turn, just so they are not snug anymore.
    I found that after I did this, the plate was a lot less crowned, as the weight of the router, and the plate not tight to the router let the plate sag just a touch.
    Now tighten the four screws up, tight, if they are North South East and West, go N to S then W to East.
    Check it again, my results were that the crown was still there, but a LOT less pronounced.
    Tampa
    281
    Thanks Stu,
    I'll give it a try. I am working on the fence right now and the motorized riser system. I think it's going to work but I need to find a spare power screw driver I dont need (good luck) for the drive system.
  1. My door warped
    By John Daugherty in forum General Woodworking Q&A
    Last Post: 02-15-2016, 03:45 AM
  2. LV router base plate for table
    By Cynthia White in forum Classified Ads
    Last Post: 11-03-2011, 12:07 PM
  3. chuck plate/face plate
    Last Post: 10-27-2009, 05:17 PM
  4. My first bowl warped....now what?
    By Tom Baugues in forum Turning Tool Questions and Show & Tell
    Last Post: 07-04-2009, 03:19 AM
  5. Warped and Wormy
    Last Post: 06-21-2007, 02:02 PM
