Results 1 to 10 of 24
Thread: Elementary Turning Blank Question
    Jun 2010
    3,220
    Hi all,
    Okay, I don't turn and know nothing about turning. In another thread I discuss cutting down several knotty maples in my yard. My question is, in order to cut/save some "turning blanks" for my lathe-mongering Family, how do I cut them?
    1. Are they just square blocks of wood with a knot or burl in the center?
    2. I understand I should coat them with Anchorseal (assuming I can get it in Canada) while they are waiting for a new home. Is there any substitution for Anchorseal? Beeswax?
    3. How big should the blank be? How much margin do I leave around each knot or burl?
    4. Should I remove the bark before coating them? and if so, how? with what tool?
    THANKS
    AKA The Rookie
    May 2009
    Lufkin Texas
    105
    If your "lathe-mongering Family" is going to pick them up, just save some sections and let them do more of the work. Try not to cut through the middle of a burl (unless it is huge). The portion just above ground level will likely have some curly figure it in that they will love. If you need to cut it up for some reason, best to talk to the lathe owners about what size they want.
    Jul 2010
    Central PA
    17
    This site has a brief description o cutting a basic bowl blank...
    http://www.nestlerode.org/Fun_with_Chainsaw/turning_blanks.php
    Burls would be handled a bit differently, but this the basics.
    12,247
    Cynthia as to preserving them you can coat the ends with pva paint if you have some lying around. Color wont matter just need to seal the ends.
    BYW if you really want to get fancy and have a substitute for anchor seal in Canada you can get this at Lee Valley and its meant to do the same thing.
    As to how to cut them i will leave to the turners here to comment on. My skills and knowledge in that department leave a lot to be desired.
    Jun 2010
    3,220
    Thanks everyone:
    Rob, what is "PVA" paint? I don't know about the fancy part, but I will be driving by a Lee Valley next month........
    AKA The Rookie
    12,247
    Just your normal water based house paint. Acrylic paint. Its cheap if you have some left over cans or your turner family might have some. Rather than you shelling out for special stuff. Save the coin for tools of your own.
    Latex Paint
    Another cheap way to seal the ends, though not as good as a green wood sealer like Anchor Seal, is take regular white glue, and mix it 2/3 glue 1/3 warm water, then paint that on.
    Jun 2010
    3,220
    Thanks all.
    If I'm sealing big pieces, should I put sealer over the bark too?
    AKA The Rookie
    Quote Originally Posted by Cynthia White View Post
    Thanks all.
    YUp....
  1. Problem turning "Willow" bowl blank UPDATED with PICS
    By Tom Baugues in forum General Woodturning Q&A
    Last Post: 08-23-2014, 08:06 AM
  2. Elementary Crosscut Sled Question
    By Cynthia White in forum Jigs and Fixtures
    Last Post: 01-22-2011, 08:46 PM
  3. Beginner's Turning Blank Question
    By Sean Wright in forum General Woodturning Q&A
    Last Post: 01-13-2008, 11:59 PM
  4. Peppermill Blank Question
    By Pete Jordan in forum Lathe Project Showcase
    Last Post: 12-31-2007, 01:55 AM
  5. Blank Question
    Last Post: 06-30-2007, 04:51 PM
