Results 1 to 10 of 16
Thread: finished HF
    3,132
    finished HF
    well i just put the last coat of finish on this HF. It's a piece of Larrys chocolate.Thanks again Larry. As some of you no i had a problem with the tenon coming off. well thanks to the guys here i got it fixed and was able to finish hollowing it. It turned out to be 13x61/2. didn't like the large opening i had in it, so i closed it down. All comments welcome as always.BTW will be buffing this in a week or so.
    Steve
    Attached Thumbnails Attached Thumbnails 003 [800x600].JPG   006 [800x600].JPG   014 [800x600].JPG
    Sep 2007
    Plainwell, Michigan
    4,857
    Nice HF I like the shape and the chocolate
    3,132
    Quote Originally Posted by Tom Niemi View Post
    Thanks Tom. that chocolate is really nice juster from a great guy.
    Goodland, Kansas
    4,834
    That is a beauty. Really nice form and finish.
    Bernie W.
    Jun 2007
    4,944
    A beautiful bowl made from a beautiful piece of wood. Maybe some day I will be able to do that.
    Enjoy,
    Jim
    VOTING MEMBER
    30,017
    Sweet! Glad you were able to save it. At 13" in diameter, it's a biggun, and I like the collar idea, too. You did a fine piece of wood justice. It should buff out nicely, too. If you have several coats of a good film finish (lacquer, varnish, or poly) and you want to go for an ultra smooth surface, wet sand it lightly with 600 grit before buffing it. It'll make that Michigan chocolate shine and feel like glass.
    3,132
    Quote Originally Posted by Bernie Weishapl View Post
    Thanks Bernie was worried i might loose it when the tenon came off.
    Quote Originally Posted by Jim C Bradley View Post
    Enjoy,
    Jim
    Thanks Jim.Wasn't sure if it would turn out like i wanted, but i think if i can do it you sure can.
    Thanks Vaughn. I'll take ya up on how to finish, as i do have 3 coats of sanding sealer and 3 coats of lacquer. That should be enough don't ya think?
    30,017
    Steve, six coats should be about right. Just wet sand by hand with a real light touch and watch the surface closely. As soon as you see and feel the surface variations go away, move to another spot. If you do happen to sand through the finish (it's happened to me plenty of times), just hit it again with a couple or three more quick coats and try again. After sanding, buffing with tripoli (or Don Pencil's PL compound) will remove the 600 grit sanding scratches and it really pulls the shine to the surface. If all the pores are filled with finish, you can follow up with white diamond and wax. If there are still some visible pores, I'd skip the white diamond and go straight to the wax. It's worth all the effort, especially on a special piece of wood. Here's an example of the kind of finish you can get. Check out the reflection of the finial on this Michigan chocolate...
Name:	HF056 - Finial and Finish Detail.jpg
    I think your piece is gonna rock.
    17,472
    Well done bud,, you just might get another piece some day from that ole buzzard
    Apr 2008
    Texas
    199
    Stephen,
    Very nice form. Good flowing lines and the collar works well. Good Work.
    Alan
  1. Finished, more or less :)
    Last Post: 09-17-2013, 12:01 AM
  2. Home bar, stools, and sofa table for my son-FINISHED, FINISHED, HOOORAYYY!!!
    Last Post: 09-18-2011, 03:36 PM
  3. I'm finished already!
    By Pete Jordan in forum Lathe Project Showcase
    Last Post: 02-03-2009, 03:44 AM
  4. Is it finished?
    By Jim Burr in forum General Woodturning Q&A
    Last Post: 10-02-2008, 09:51 PM
