Results 1 to 4 of 4
Thread: Collet Extender
    Collet Extender
    I use a router sled from the book by Bill Hylton to straighten warped boards. There are times when the bit is too short and I have to raise the warped board. An easier way would be to put a collet extender in the router. So I'm looking at the CMT extender. I would appreciate comments from people who have used the extender. I'm mainly concerned about vibrations and run-out of the extender.
    Thanks, DKT
    I put one in my Hitachi M12, the >> Xtreem-Xtenstion <<, it was time consuming to set up right the first time, had to fiddle with it, but now it is set up, it works great. Biggest thing is to leave a small space between the end of the extender shaft and the bottom of the collet on the router, if they touch, you get a ton of vibration, so there needs to be a space.
    I'm sorry I don't have any experience with the CMT unit.
    9,077
    I have the cheap-o Woodline version and it does not give me vibration problems (I was surprised due to the reasonable price; $20 at the show). The collet design is not self-releasing so at first I though it had a problem; it was just functioning as designed.
    I put one in my Hitachi M12, the >> [URL="http://www.routertechnologies.com/extreme%20extension.htm"][B]Biggest thing is to leave a small space between the end of the extender shaft and the bottom of the collet on the router, if they touch, you get a ton of vibration, so there needs to be a space.
    Thanks for the reply. As far as the bit bottoming out, as a general practice I always leave a space between the bit and the bottom of the collet. But it's is a good reminder nevertheless.
    DKT
  1. Router collet extensions
    By Royall Clark in forum General Woodworking Q&A
    Last Post: 10-29-2014, 03:02 AM
  2. raffan collet chuck
    By Dan Noren in forum General Woodturning Q&A
    Last Post: 02-24-2011, 03:28 PM
  3. Collet issue
    By Tony Maio in forum General Woodworking Q&A
    Last Post: 07-27-2009, 11:48 AM
  4. Expanding Collet Chuck ??
    By Jeff Bower in forum New Tools
    Last Post: 12-06-2007, 10:27 PM
  5. Bessey Extender
    By Jay Lock in forum New Tools
    Last Post: 12-27-2006, 09:05 PM
