- Reno NV
Kinda figure it won't hurt. Spray foam should hold the steel wool in place.
I looked at some, but what I found was a lot thinner than rat shields I've seen. Thanks for the suggestion though.
I'll probably go with the steel wool and spray foam for now. It's starting to get down in the 30's at night, so need to get moving on putting the walls back together. There's a 2X6 going around the base of the shop, so I'll just fill in about half way down, then it won't interfere with rat shield installation when I come across some.
That's a big building. Do you think you'll be able to block all the areas of ingress for the rodents? Darn persistent critters they are...
