Results 1 to 8 of 8
Thread: pocket doors.....
    Hedgesville,WV
    158
    pocket doors.....
    let me start off saying that this is my 1st attempt at this. I'm building a 2-piece ent. center for the wife, and now I'm at a standstill. I've installed both sets of slides(KV),and they work fine with the follower strip. now the cup hinges.. well, I made a test door, following the measurements provided: 1.5" down from top/bottom edges, but it's not real clear on how far in from the sides to locate hole center?? The plans seem to have a vast array of measurements, but none that I see for this. also, on the test door, after hooking up top hinge, the bottom hinge is off by half the width of the hinge arm.All the measurements are w/i 1/16th, so I'm lost. I don't wanna move either slide, as they roll great. how about marking the locations of each hige while attached to the slide?? I don't understand how they could be off that much???
    "Treat everyone equally,keep your word, and overlook peoples' mistakes...you'll make plenty yourself "..... spoken to me by a much wiser man than I.
    5,323
    Quote Originally Posted by James Edwards View Post
    ...now the cup hinges.. well, I made a test door, following the measurements provided: 1.5" down from top/bottom edges, but it's not real clear on how far in from the sides to locate hole center??...on the test door, after hooking up top hinge, the bottom hinge is off by half the width of the hinge arm.All the measurements are w/i 1/16th, so I'm lost. I don't wanna move either slide, as they roll great. how about marking the locations of each hige while attached to the slide?? I don't understand how they could be off that much???
    By 'cup hinges' I'm assuming you mean the Blum/Hafele type Euro hinges? If so, I usually position the 35mm hole so that its edge is about 1/8" (3mm) in from the door's edge.
    As for the vertical spacing, use the center-to-center spacing on the slide, and then transfer it to your door, keeping it centered between top & bottom.
    That oughtta do it fo you.
    Hedgesville,WV
    158
    yeah Jim, they're Salice(whatever that means) 40MM Euro hinges... so you use 1/8" ?? ok, I'll try that...Thanks
    17,476
    salice is another brand, and jim is spot on with his answer..
    5,323
    Are you sure they're 40 mm? 35 mm is pretty much the 'standard' for Euro hardware. BTW, 35 mm is almost exactly 1-3/8 inches.
    1-3/8"=34.925 mm
    Purty close
    For some reason alot of the pocket door slides use hinges with 40 mm cups. I liked the ones blum used to make that used a cable system to align the doors and to keep them from sagging.
    Hedgesville,WV
    158
    heck yeah, there 40MM... had to drive 45 minutes to get one from the Rockler store...
  1. doors
    By Chuck Thoits in forum Carpentry and Construction
    Last Post: 03-26-2008, 12:22 AM
  2. doors doors and more doors
    By Robert Schaubhut in forum Flatwork Project Showcase
    Last Post: 06-29-2007, 12:30 AM
