Results 1 to 10 of 21
Thread: Thinking about my next tool purchase.
    Smile Thinking about my next tool purchase.
    Well with my new shop just around the corner I'm thinking about my next tool. I'm torn between a Joiner or a shaper. I have been getting along with my planer and TS but a nice 8" joiner would be nice however, I also think that a shaper would be more useful. Right now I have a router table built into my TS that works OK but I know a shaper would quickly be a lot better. And if I needed to edge joint some boards I could do it on the shaper. The only thing I wouldn't be able to do is face join and I do that now on the planer. So what do you guys think. One of the local machinery suppliers has several old Arn shapers in stock ranging from $650 - $950 less tooling.
    Sacramento, CA
    1,367
    To me, it's a no-brainer. You really need a jointer before you need a shaper. Unless you're using sleds of some kind or painstakingly hand-planing your stock before running them through the planer, you won't end up with perfectly straight, square stock. Yeah...a jointer's one of those staples in a shop.
    Since you already have a router table, a shaper's a luxury (and an expensive one, at that). Especially when you consider the price of cutters for the thing. Lotsa steel and carbide in those things.
    Now, that's my view. I don't run thousands (or more) of feet of moulding regularly. I don't make flooring. My profile jobs are usually under 10 feet of linear cut almost always. What I do make is furniture with mortise and tenon joinery and dovetails and miters that would be lost without truly straight and square stock to begin with. So you have to take your needs into account.
    Jason Beam
    Sacramento, CA
    don, as you know i haven`t had a jointer in my shop for over 20 yrs...and i don`t miss it.....if my shaper died i`d do whatever was required to have it up-n-runnin` a.s.a.p.
    if you opt to go the shaper route do yourself a favor and budgit in a feeder at the same time.....tod
    Charleston
    917
    Don,
    I am fortunate that I have both and I use the jointer far more than the shaper. I would suggest the jointer and if you need more horsepower for the router table then that becomes a dual purpose device that can be used as a shaper when attached to the table. Just my two cents, but it is my opinion.
    Steve Clardy Guest
    I have both. Cannot do without the jointer.
    Shaper is used for raised panels only.
    The Heart of Dixie
    4,268
    I was going to say jointer too. After I got one I wondered how I ever did without one. Got my shaper going and I love it. But I didn't have a router table (or want one honestly). Assuming you have money tied up in bits the jointer seems like an easy choice.
    Now you have my curiosity up Tod. What methods are you using? Do you work with saw mill/rough lumber or is your faced? Inquiring minds want to know.
    Custom built boats and Kits
    The Ocean State
    170
    Simple...you can use a shaper as a jointer...but you can't use a jointer as a shaper. At least I haven't figure that one out yet.
    Steve Clardy Guest
    Ok. Got me curious.
    How do you edge a 8' board thats been in a shipwreck with a fence on a shaper thats 20" long [Easily]
    Nova Scotia's beautiful south shore
    443
    Quote Originally Posted by Jason Beam View Post
    I agree with Jason and I'll even go a step further. I think you should add up the cost of shaper and an assortment of cutters (plus a power feed) and compare that to the cost of a 12" jointer. An 8" jointer makes little sense to me - it'll leave you wishing you'd gone for a bigger model.
    FAS lumber has to be a a certain width - around 10" after drying, I believe. Around here most of the FAS hardwood is just over that limit.
    It's usually wise to rip boards that wide to avoid cupping, BUT with a 12" jointer you can make the decision. For that special table-top or other places where seams are undesirable, you'll have the capacity for wider boards.
    I have a 4" jointer - my only piece of old iron It's a joke for face jointing, but I didn't buy it for that. If I ever upgrade it'll be to the 12"-16" range. The big'uns hold their value a lot better too.
    All the best,
    Ian G
    **Now holding auditions for a catchy new signature**
    The Ocean State
    170
    Shaper ain't nothing but a jointer with the a cutter that is verticle. Fence is easy...right? Straight bit...like this http://www.amazon.com/Magnate-M048-S...7?ie=UTF8&s=hi
    can be used to edge that hunk a wood...you got yourself a verticlue jointer. Bin there...done that.
  1. Who is always thinking of buying a tool they don't really need?
    By keith Boutselis in forum General Woodworking Q&A
    Last Post: 08-16-2012, 07:19 PM
  2. Where to purchase
    By Bart Leetch in forum Turning Tool Questions and Show & Tell
    Last Post: 10-01-2008, 06:28 PM
  3. Thinking to buy a vintage tool
    By Fidel Fernandez in forum Neander Woodworking Q&A
    Last Post: 05-30-2007, 12:16 AM
  4. I need help with the next tool purchase
    By Mike Gabbay in forum Neander Tool Questions and Show & Tell
    Last Post: 12-15-2006, 05:56 PM
  5. Well, I'm thinking of a new TS or other tool.......
    By Mark Rios in forum General Woodworking Q&A
    Last Post: 11-17-2006, 11:41 PM
