Results 1 to 10 of 12
Thread: Bandsaw table questions
    I recently bought an older delta/rockwell band saw and It looks like someone attacked the table top with an angle grinder and there are some thin but slightly deep gouges, too deep to sand out that I want to fix. I'm thinking maybe I could put a small weld over it and then file it down.
    Feb 2009
    Whittier, CA, USA
    512
    Stu fixed up his cast iron drill press table by pre-heating and then filling in the bad parts with welds.
    Stu's drill press rebuild
    Cheers,
    Dan Gonzales
    Whittier, CA, USA
    Dona nobis pacem
    Thank You for that link, however I am worried about cracking in the table. Its not as bad as stu's table.
    11,828
    Quote Originally Posted by Dimitri Schreiber View Post
    I was going to say, just smooth the top and don't worry about it. But, if you think the top might crack then welding or brazing might be called for.
    If cracking is not a concern I would just smear in some JB Weld and sand, or file, the fix smooth.
    30,008
    If you're just looking to fill the gouges and level the top of the table, I think my first approach would also be JB Weld, as Frank suggested, or even Bondo. Another possibility would be an auxiliary table attached to the existing table (melamine-covered MDF would work). You'd lose 5/8" or 3/4" of cutting capacity depth-wise, but unless you're often using the full capacity, it probably wouldn't be a problem. Personally, if they don't impede the wood when running it through the blade, I'd probably just live with the gouges. At least for the bandsaw work I do, table flatness hasn't ever been a real critical issue.
    The Heart of Dixie
    4,268
    I have restored a few old machines and my advice is leave it alone! Sand or file the edges smooth and flat so nothing catches on it and just use it. A few months from now you will not even notice it. Yea it looks bad, but so what? How it works is what matters and as long as it is not causing a problem your better off to leave it alone. Trying to repair it could ruin the table.
    Custom built boats and Kits
    Ok, what I was wanting to do was just for looks. I was wanting to try to make it look like new. I'm currently stripping the paint and I am about to get a welder and make a media blasting cabinet out of a 55 gallon drum/barrel and then blast the whole thing. Powdercoat the smaller parts, use my paintsprayer on the larger parts.
    Mar 2010
    Decatur, Alabama
    518
    If it's cast iron, I would suggest leaving it alone or trying some bondo/loctite epoxy/belzona type products. Cast steel can be welded with pre/post heat. Cast iron can't really be welded, although you might be able to fill in holes. Structural welding on it has always had pretty poor results in my experience. It will be very prone to popping out pieces. You can braze it from what I've read/heard. Something to do with the thermal expansion as it cools + the high carbon content in cast iron is much more brittle than steel makes welded joints fail easily.
    17,471
    another thought here, you said you want it to look like new.. well if your dismantling the saw for this redo ,,maybe you could have a machine shop regrind the top for you from the sounds its a light cut and it would be as good as new if you got a friend in the machine shop business.. i bet you could get it done for under a fifty bucks if you had to pay for it.
    5,320
    Yeah, an auto machine shop could likely do it for you. They grind engine heads all the time. A nice Blanchard grind would make your saw table look better than new.
  1. Questions on a Craigslist Bandsaw
    By Mike Barger in forum New Tools
    Last Post: 11-23-2011, 04:19 PM
  2. Bandsaw Questions
    Last Post: 06-15-2010, 09:08 PM
  3. Bandsaw Questions
    Last Post: 05-19-2010, 03:15 PM
  4. bandsaw purchase questions
    By John Daugherty in forum New Tools
    Last Post: 03-02-2008, 05:16 AM
  5. 14in Bandsaw Questions
    Last Post: 07-27-2007, 09:40 AM
