Results 1 to 5 of 5
Thread: Daughter up to bat with hollow forms
    Palm Springs, Ca
    1,167
    I got turn another hollow form today and I was really liking how things were going. I was turning the section near to the neck and I think the cutter must have moved (or I had it set to thin) on me because I sliced thru the side wall in one part of the vessel. Soooooo, I stood there cussing for a bit and then thought ahhhhh well and I was going to throw it in the firewood pile when my daughter came out. She asked about it and I explained what happened and was going to throw it out - but she wanted it with the addition of a cut out pattern she drew on it.
    Picture 1,2,3 - Im not over thrilled about it but she likes it and wants it finished shinney with a top. So next step is the top and to finish it. Currently sitting inside after a couple coats inside and out with DO........11" tall and 7 1/4" wide
    Picture 4 was a refinish on a bowl - very bland - daughter wanted it dark reddish color so .............walla.........spray laquer finish and now drying. A bit to dark perhaps but again she likes it ......4" tall and 7" wide ....LOL
    Picture-5 tall vessel sitting inside to cure the 3 sanded in coats of Do that were put on.......10" tall and 6" wide
    Picture -6 is my cluttered counter top in the TV room where I keep some turning stuff (small container of DO, OOOO steel wool, grey scotch pad, assorted finials, reading glasses). My wife does not like the clutter there but ignores it because I explained that everybody that turns has this stuff at there bar counter.
    Attached Thumbnails Attached Thumbnails Large hollow.jpg   Large Hollow-2.jpg   Large Hollow-3.jpg   Red.jpg   Hollow-4.jpg
    S E Washington State
    3,777
    Your daughter has good taste. I really like her cut-out idea also, really add to the piece.
    17,470
    i can see that holding a light in side and mking its way to a elegant end table.. nice idea for the gal,, you should consult with her more
    Los Angeles, CA
    2,668
    I think you should team up with her more often.
    Palm Springs, Ca
    1,167
    Larry your right and I may just do that.....she can use it for a lamp....
    Yep she saved it from the designer wood pile i have.......but today is another one for turning or so im hoping with some workers comming and I have to be around so I just may get a bit more time out there to try again.
  1. Some Hollow Forms
    By Wayne Bower in forum Lathe Project Showcase
    Last Post: 07-25-2008, 08:40 PM
  2. My First Hollow Forms
    Last Post: 04-25-2008, 11:49 AM
  3. Hollow Forms #9 and #10
    Last Post: 04-05-2007, 10:03 PM
  4. Hollow Forms #2 and #3
    Last Post: 03-11-2007, 07:32 AM
  5. Hollow forms form
    By Roger Turnbough in forum Lathe Project Showcase
    Last Post: 02-28-2007, 03:40 PM
