Results 1 to 10 of 16
Thread: Dowel center jig
    Aug 2010
    Madison Lake, Mn
    38
    Dowel center jig
    I need to find a way to find the exact center of the end of a dowel rod. I have a metal lathe but the spindle hole often is not big enough. I really don't want to buy another tool that I so seldom use. Does anybody know any tricks for finding the center of the end of a wood dowel?
    Ken
    Wood worker wannabee
    W0CSC
    Semper FI
    11,832
    A center finder is a very valuable tool in my shop, and, I suspect, almost everyone's. Adjustable squares often are designed to do this chore also.
    With shipping, at under $10.00, I consider this a 'must' item.
    Forget link: http://www.woodturnerscatalog.com/st...o_finder?Args=
    868
    Quote Originally Posted by Ken Schweim View Post
    Hi Ken; Here's a slick little item I use for finding the centre of pen blanks. No reason that I'm aware of that it won't work on dowels!http://www.penturners.org/forum/showthread.php?t=61910
    Mack C. in Brooklin ON
    It feels great to sell a pen,
    I am a proud supporter of
    Southeast Pa
    2,019
    This style is terrific.
    http://www.amazon.com/Groz-CS-2-Cent.../dp/B001DT3S2Y
    This one is also nice..
    Garry
    4,552
    A Turn N Time
    Frog Pond Guitars
    Bob Wiggins is offline Former Member (by the member's request)
    140 miles west of tulsa
    125
    One problem I've found with attempting to locate the center of dowels (especially purchased) is they are all out of round.
    I thought all machinists had a combination set that contained a center head for locating the center of round stock.
    When accuracy is important I've used a single edge razor for marking.
    13,361
    Here's a little different take on it.
    You could drill a hole the size of the dowel in a block of wood and then use a transfer punch to mark the center on the dowel...
    I've got a set of transfer punches from HF I use mainly as pen disassembly tools when things go wrong...
    transfer punch set
    Aug 2010
    Madison Lake, Mn
    38
    dowel center jig
    I can't believe Grizzly is $12 cheaper than Amazon! Brent - your idea really hit home....good thinking. I think however after much thought and discussion with my accountant (wife) that we are going to our secret vault and withdraw the funds to buy the Grizzly version. For that price it just ain't worth screwing around with my eyeballs trying to find center....at my age and eyesight I have all I can do to find the end of the dowel. Thanks for all the replies....this forum is awesome!
    Ken
    W0CSC
    Semper FI
    Southeast Pa
    2,019
    Quote Originally Posted by Bob Wiggins View Post
    You know it is funny how silly some of this stuff gets. After my posting with my humble recomendations, I went searching via Google to see what others used. The same question had been posted on another site with generally the same answers. However one guy basically said that the only right way to do the was buy a Starret brand set like that for 200+ dollars and if you went any other way basically you were cheap, would be unsatisfied for life and never get close enough to the center of anything.
    A 200+ plus tool specifically for finding the center of a wood Dowel that is unlikely to be that close to a real circle in the first place. Makes the 70.00 dollar screwdriver look reasonable.....
    11,832
    Out of round no problem, just make about four stops around the edge with the center finder, the center will be inside a small outlined area.
  1. Dowel Bit
    By John French in forum General Woodworking Q&A
    Last Post: 05-17-2012, 03:06 PM
  2. Inexpensive safety center/dead center
    By Mike Mills in forum Turning Tool Questions and Show & Tell
    Last Post: 01-25-2012, 11:50 PM
  3. How do I cut a dowel in half?
    Last Post: 05-21-2011, 11:40 PM
  4. dowel pin maker
    Last Post: 07-14-2010, 04:12 PM
  5. Dowel pins
    By Jay Caughron in forum Old Ads
    Last Post: 11-17-2008, 09:28 PM
