Results 1 to 10 of 14
Thread: Spalted Blue Keyaki.....
    15,811
    ... this and it's twin are going to be presents for my lovely wife, this is the last of the Blue Keyaki I got during my Logging in Tokyo adventure.
    These blanks were cut round and then waxed up and left in the Dungeon annex for a few months before I got the dehumidifier installed in there.......... yep, they started to spalt
    I've not finished it yet, it has to have the bottom done.
    I did put two heavy coats of that Salad Bowl Beeswax finish on it that LV sells.
    This finish takes a while to dry, but is food safe and I like the look
    Lots going on in this piece
    Not too shabby
    Well I hope there were enough pics of it..........
    BTW, I'm really liking the new bowl jaws I got for my Nova G3 chuck, they sure hold tight!
    Central CA
    797
    Hubba Hubba Choolubba, Stu! That's GREAT!
    Thanks, Mark.
    Custom Bonehead.
    My diet is working good. I'm down to needing just one chair now.
    "Just think how stupid the average person is, and then realize that half of them are even stupider!" --George Carlin
    Southern Georgia
    1,396
    Wow Stu,
    Very very nice indeed! I'm sure your wife will be pleased, as she should be!
    - Marty -
    Fivebraids, Inc.
    When you earnestly believe you can compensate for a lack of skill by doubling your efforts, theres no end to what you cant do
    15,811
    Anyone give a course on how to save a badly orbited bowl...........
    While finishing this bowl, using a jab chuck method, the last bit of the tenon went "CRACK" when I was not ready for it to do so, and the bowl bounced around between the headstock and the live (POINTY BIT) center for a moment until I could stop the lathe.............BAD words were said...........
    Man I just about cried.........
    I think I can save it, one crack that I already glued, and a bunch of little divots all round the outside.......
    I'm thinking of filling the divots with some espresso grounds and CA glue and then sanding........ MAN was I down, all I could to to NOT fling it across the Dungeon and then jump up and down on it several times............
    No pics, because, if there are no pics, it didn't happen........ right..........?
    I sure hope I can save it, I'll be REAL bummed out if I cannot, wish me luck.......... I'm going to bed.......
    15,811
    Well, I had at it with the espresso grounds and some thicker CA glue, I think it turned out fairly well, all things considered.
    I hope the divots look like worm holes etc, but I'm not saying nothing
    It just needs another coat of wax, and then a final buffing....
    Such a nice looking piece of wood, I have one more like it to go.
    PS thank the good Lord for sandpaper
    30,225
    Nice save Stu, on a very nice piece of wood. Sandpaper is indeed another turning tool.
    15,811
    Funny, when I saw Eli Avisera turn here, he was very quick to point out that sandpaper is indeed a tool that everyone uses, but he also told us that in his opinion, having more tools to reduce the amount of sandpaper you uses, is a good investment, as sandpaper is not cheap and most only get one use out of it, while the proper tool may cost more up front, you should be able to use is for a long time
    Food for thought.
    Michigan
    2,436
    I think it looks great Stu, and to me it does look like worm holes. Nice job!
    And I consider 80 grit as a turning tool....
    Central CA
    797
    Hey Stu, at first I was wondering how you went through all that wood from your loggin excursion but then I remembered that you slabbed most of it right? Hows that wood doing? Did you get a lot of spalting in the slabbed stuff? Any ideas for upcoming projects with that material?
    BTW, I just had a question come up and I sent you a PM.
    Thanks, Mark.
    Custom Bonehead.
    nice save stu! that`s a pretty bowl even if i can`t pronounce the word after blue ......tod
  1. So Very Blue
    By Stuart Ablett in forum Flatwork Project Showcase
    Last Post: 12-06-2014, 02:02 AM
  2. From out of the blue
    Last Post: 11-09-2013, 04:33 AM
  3. Keyaki Mallet
    Last Post: 10-31-2012, 01:26 PM
  4. Spalted Blue Pine with Knot
    By Ron Hossack in forum Lathe Project Showcase
    Last Post: 06-23-2011, 11:09 PM
  5. Big Blue's Last Job
    By Bill Grumbine in forum Lathe Project Showcase
    Last Post: 08-24-2007, 09:09 PM
