Page 1 of 4 1234 LastLast
Results 1 to 10 of 35
Thread: Twist-Lock vs Normal Plugs and Outlets on 220V Tools
    Feb 2010
    Apex, NC
    6
    I was wondering how people felt out using twist-lock (L6-20) plugs vs non twist-lock (6-20) plugs on their mostly-stationary power tools (table saw, bandsaw, jointer, etc)?
    The table saw I have came with a 6-20 plug on it, but I need to make it a bit longer so I am debating using twist-locks on a new cable, and the jointer and bandsaw don't have plugs yet. (I haven't figured that reasoning out yet since they're all from Grizzly.)
    The outlets I had installed were twist-lock because at the time I thought that would be a bit more secure, but then I started thinking that maybe that's not the best thing of somehow I managed to trip on one or drop a board on one.
    Anyway, I was just wondering what people were using and what they thought the pros / cons were? The non twist-lock parts are certainly cheaper, but not by so much that it matters at this point.
    -Doug
    Constantine, MI
    7,891
    I use twist lock, but all my 220's are drops from the ceiling. A normal plug would not have worked. I've not given it a lot of thought, but your point about tripping over a cord that is solidly connected to the wall gives one reason to speculate.
    www.wrworkshop.com
    I have the L1420 non twist lock.
    5,322
    Tablesaw, Bandsaw, Dust Collector and Compressor all have twist locks. I won't use anything else.
    Mine are not twist-lock which I doubt would help me if I tripped over the cord. They fit quite snug and my outlets are all four feet off the ground. I added my own cords and made them long enough for a comfortable service loop so, no guitar-string-tight runs to trip over. As long as the plug and socket meet the requirement, the format is your choice.
    3,134
    I don't remember what plug I have but it has a horizontal spade & a vertical spade with the ground between. No twist lock for me. If it can't come out of the plug-in the plug-in can be broken not to mention me falling flat on my face.
    When I replace the factory cord I install a 15' cord 2-12 with ground.
    Feb 2009
    Whittier, CA, USA
    512
    I use straight NEMA 6-15 plugs on my table saw, jointer, planer and the extension cord that goes to the house. I chose the straight plug option because they were cheaper than the locking ones. The one thing I like about most locking cord plugs and receptacles is the easier grip due to their size. For drop lines you can't beat the locking NEMA L6-15 or L6-20 fixtures.
    Another thing to consider is that portable generators usually only take the locking fixtures. That is why contractors usually carry locking extension cords and pigtails.
    Dan Gonzales
    Whittier, CA, USA
    Dona nobis pacem
    You got a problem with them falling out? Overhead plugs, they are great. normal use plugs they are a pain in the tushie. Costs too much, difficult to lock in, just a royal pain..... But then, that is my opinion.
    Quote Originally Posted by Dan Gonzales View Post
    I use straight NEMA 5-15 plugs on my table saw, jointer, planer and the extension cord that goes to the house. I believe chose the straight plug option because they were cheaper than the locking ones. The one thing I like about most locking cord plugs and receptacles is the easier grip due to their size. For drop lines you can't beat the locking NEMA L6-15 or L6-20 fixtures.
    My portable generator, a Coleman Powermate uses the non twist type, That why I went with then in the shop, I have a double ended cord so I can back feed the power panel in the event of a loss of power through the shop.
    Feb 2009
    Whittier, CA, USA
    512
    I said usually
    Dan Gonzales
    Whittier, CA, USA
    Dona nobis pacem
  1. We're back to normal
    By Chuck Ellis in forum Off Topic Discussion
    Last Post: 06-17-2013, 09:40 PM
  2. Bringing 220V in the garage/shop
    By Mohammad Madha in forum Off Topic Discussion
    Last Post: 09-11-2011, 06:26 PM
  3. Aluminum twist lock rings from Woodpeckers
    By Alan Bienlein in forum New Tools
    Last Post: 04-09-2011, 12:36 PM
  4. Not NORMal router table
    Last Post: 02-09-2008, 05:22 PM
  5. 220V remote?
    By ken werner in forum General Woodworking Q&A
    Last Post: 11-28-2006, 01:28 AM
