Results 1 to 6 of 6
Thread: water stones
    3,134
    water stones
    How long does it normally take for water stones to dry out, the temperature here is mid to high 70's? I have taken mine out of their water reservoir to dry out so I can store them which may be in an unheated area.
    17,475
    i guess you could use the weight of the stones approach like they do for wood being dry bart..wouldnt dare give you a time and have the freeze and break
    Good question Bart
    I think Larry has the best answer, weigh it when it comes out of the water and call it dry when it stops losing weight
    I think it would depend a lot on the stone's size etc too
    Bellingham
    2,450
    Gee Bart, it is still August. Are you expecting an early freeze here?
    Central NY State
    3,374
    Bill said what I was thinking. Maybe you shouldn't store em where they freeze. I once had a bucket of stones freeze solid. When I thawed them out, the only one that broke was [of course] the finest at 6K. Anyway, I think when they feel dry, they're probably dry enough, but I'm just guessing, and after my experience, I never did leave them in an unheated shop again.
    Baltimore, Ontario, Canada
    14
    Would that depend on the humidity? You can take the stones out but they will only dry out to what ever the humidity is in the room. Of course the colder it gets the less humid it becomes. If you were to seal them in tupperware after they dry out could they still break because you've sealed them in with whatever humidity was in the room when you sealed them. I think I would store them so they could breath (ie. react to room humidity) by wrapping them in newspaper or whatever and in a normal cardboard box. Just a thought....
  1. My new Arkansas slip stones have arrived
    By Rob Keeble in forum Carving
    Last Post: 03-11-2016, 08:17 PM
  2. Those touch up slip stones.....
    By fred hargis in forum General Woodturning Q&A
    Last Post: 07-15-2014, 07:04 PM
  3. Fine Cement-working - Cap Stones
    By glenn bradley in forum Carpentry and Construction
    Last Post: 08-11-2010, 11:55 AM
  4. Ceramic Water Stones and Well - ** SOLD **
    By glenn bradley in forum Old Ads
    Last Post: 09-10-2008, 06:46 PM
  5. DMT Diamond Sharpening Stones
    By Keith Starosta in forum Old Ads
    Last Post: 06-01-2008, 01:34 PM
