Results 1 to 4 of 4
Thread: Save Wear on your Wet Wheel
    I bought dad a Jet slow speed wet sharpener and some Tormek jigs for it. I only have one gouge and was enamored by the Tormek gouge jig. We both have the WorkSharp and I thought of a way to do steps that required a lot of metal removal that work for me (without a slow speed machine) and for him prior to using the slow speed machine.
    Take a piece of hardwood scrap and make an opening about the shape of your tool(s). Drill a perpendicular hole and tap it. Thread in a knobbed stud (or is it studded knob?).
Name:	a-WS Gouge Jig.jpg
ID:	48620Click image for larger version.
Name:	b-WS Gouge Jig.jpg
    Slip the gouge in and find the angle similar to the method used on the Tormek/Jet or what have you. Lock it down with the knob. Keeping the face of the jig against the bar, use nice smooth sweeping curves.
Name:	c-WS Gouge Jig.jpg
ID:	48622Click image for larger version.
Name:	d-WS Gouge Jig.jpg
ID:	48623Click image for larger version.
Name:	e-WS Gouge Jig.jpg
    Work your way through 2 or 3 grits and you end up here.
Name:	f-WS Gouge Jig.jpg
    For me this is done as I use this method on my one carving gouge at about 30* IIRC. For some of you spinners (45* - 55*), its off to the slow speed sharpener to really shine her up.
    Bellingham
    2,449
    Hey that is a good idea! Thanks
    17,471
    got to keep them in line the ole foggies,, and teach us yunguns a thing or two as well thanks glenn
    30,014
    That's a slick idea, Glenn. It'd work great for traditional gouge profiles. For other profiles, like the "fingernail" or "Ellsworth" grind a lot of us use on bowl gouges, the tool clamp thingie would need to be elevated a bit higher, and the pivot point isolated to a single point on the tool rest bar. It's difficult to describe in writing, but if you've seen the Oneway Vari-Grind in action, you'll know what I mean.
  1. Glass Wearers....What Do You Wear?...Any Alternatives?
    By Mike Turner in forum Safety Tips
    Last Post: 04-16-2014, 05:56 PM
  2. What not to wear.
    By Jim Burr in forum Off Topic Discussion
    Last Post: 04-04-2014, 11:39 PM
  3. wear vrs dollars? cordless drivers...
    Last Post: 12-15-2012, 01:29 AM
  4. Do You Wear a Face Shield?
    By Vaughn McMillan in forum General Woodturning Q&A
    Last Post: 07-21-2009, 05:28 PM
  5. Why I bother to wear a dust mask.
    By Chas Jones in forum Turning Tool Questions and Show & Tell
    Last Post: 05-03-2009, 03:42 PM
