Results 1 to 10 of 11
Thread: Scratch beading
    12,247
    Scratch beading
    Ok so this amateur decide he is going to smarten up some wood befor use in a project.
    I have bought a couple of beading blades from LV and made a very quick and dirty scratch tool to hold the beading blades.
    Tried it out but it was tough going. So i am pretty sure i am doing something wrong.
    Are there any tips you guys can throw me to help me get started. I am putting a round bead about 3/4 of an in in from the edge on a piece of mahogany. Go to do 4 pieces totally about 70 inches. Dont want to mess it up. Have some to practice on and already did, but i dont think my technique is at all right.
    Any advice welcome thanks.
    5,319
    Pay close attention to the direction of the grain, and don't try to take too much off at once. Patience is called for here - big time!
    12,247
    So Jim should i start with the blade barely sticking out? Also do i roll it on its side as i go or do i keep it at 90 degrees to the wood?
    Central NY State
    3,374
    I think you have to get a feel for it. The grain can vary and require you to vary your angle. Practice a bunch on scrap it'll come to you.
    17,470
    they all have lead you right rob when i done it on my hutch it too found out the hard way on the grain factor and when you have to go in a arch its more trouble light cuts to get your track started and then progessivly more but it likes to jump the track so be in control of it and dont get lax in the passes..
    12,247
    Thanks guys for the advice. I will post some pics when i get it going. Wood i am using is African Mahogany the grain is fairly straight but the wood is stingy so i will have to watch tear out.
    Palm Beach Gardens, Florida
    185
    Hi Rob,
    Here is access to a PDF on making and using a scratch stock by one of the best furniture restorers in the world.
    http://www.johnlloydfinefurniture.co...s.asp?offset=5
    The second listing is the one but you might also want to look around at the work this man does.
    Regards,
    Bill Antonacchio
    12,247
    Thank you Bill.
    That John Lloyd article is great. I'll +1 on grain reading and patience. Rather than set the cutter at a shallow depth, I set my cutter at full depth and then just eased my way down to full depth.
    185
    Hi Glenn,
    With that scratch stock in the picture do you use one hand to hold the stock?
    Regards,
    Bill Antonacchio
  1. Cat Scratch Fever
    By Brent Dowell in forum Finishing School
    Last Post: 06-11-2013, 11:44 AM
  2. Beading Busy again.
    Last Post: 06-15-2010, 04:05 AM
  3. Beading, how do you ...
    By Richard Line in forum General Woodworking Q&A
    Last Post: 10-31-2009, 04:11 AM
  4. hand cut beading?
    By larry merlau in forum Neander Woodworking Q&A
    Last Post: 03-27-2008, 12:53 PM
