Results 1 to 8 of 8
Thread: Turned pendants
    Oliver Springs, TN
    1,190
    Turned pendants
    I'm on the list for the Pendant Mandrel pass around from Jonathan. I've never made pendants before so I thought I'd give it a try without the mandrel first to see if it's any easier with the mandrel. The wood is walnut and ambrosia maple. They weren't that bad to make and my wife and daughter scarfed up their favorites. My daughter is wanting a set of earrings to match.
    14,469
    those maple pieces are real purty !!! just think of what you can do when you a get the mandrel to play with..
    S E Washington State
    1,556
    Those are beautiful. The wood is awesome. Well done. Doesn't look to me like you need a pendant chuck to play with.
    Los Angeles, CA
    2,292
    You are more than ready for the Mandrel. Those pendants look great.
    Aug 2008
    Fresno, Ca
    2,125
    Nice work John My wife, who is a beaded jewelery maker, gave me a suggestion. Making the hole bigger allows for bigger and/or more strands to be attached. Some of mine have a 3/4" whole.
    What finish did you use...it really brings out the color in the maple.
    7,914
    Quote Originally Posted by Paul Douglass View Post
    +1 on what Paul said. Those maple ones look awesome.
    Rob .....Alias John Wayne now Pasquinell da trapper.
    "forget the apples slap some bacon on a biscuit and lets go...
    We're burning daylight"
    SoCal and/or NM
    23,013
    They all look great, John. Having done a few on the offset backer plate, I can see it'd pretty easy to do one-offs with just a faceplate or waste block and some tape. I think one of the big advantages to the offset plate is the repeatability you can get. That's one aspect the plate makes a whole lot easier to do.
    Oliver Springs, TN
    1,190
    Thanks for the comments.
    Quote Originally Posted by Jim Burr View Post
    Jim, I sanded them to 220 and the finish is 3 coats of rattle can lacquer.
    Vaughn, I used a waste block with tape. Since I've turned a few I could see how repeatability would be an advantage of the plate.
