- Constantine, MI
The plans (NYW) I'm working from use MDF for the fence. There are movable sections of the fence to either side of the bit. In the plans a "T" slot is used to capture a "T" bolt that locks the fence in place. This bothers me a bit (no pun intended) since MDF is so prone to delamination.
Has anyone built this fence in this way? Have you experienced any problems?
I was thinking about putting a grove in the fence and placing an aluminum "T" track in it. However, once you grove the MDF there is only about 1/4" of material left, not enough to hold a screw....so...I was thinking epoxy?
Any suggestions?
Any suggestions?
