Results 1 to 9 of 9
Thread: Broken screw in Hickory
    I have a broken screw (5/8" long, used on a hinge) in Hickory. Read the reviews on Rockler and Woodcraft for their extractor. Looks to me like the extractor might work on soft woods okay, but Hickory? Any suggestions?
    Thanks, DKT
    If you mean this I have used it in ash and QSWO no problem.
    Palm Beach Gardens, Florida
    185
    Can't help with getting this one out more than what Glenn has expressed, but for the future, I have read to use a steel screw in the hinge holes first then when the piece is completed put the brass screws in as the last item. Brass screws are soft and the heads will twist off when trying to create the threads in the piece of wood whatever it may be.
    Regards,
    Bill Antonacchio
    10,600
    Quote Originally Posted by Bill Antonacchio View Post
    Nice tip Bill.
    I have that extractor and it worked just fine in hardwoods for me.
    Yes, those are the ones I was talking about. I read where you have to go slow with them because of heat built-up.
    One more question: What is QSWO? Quarter sawn white oak comes to mind.
    Correct, quarter sawn white oak, sorry for the alphabet-soup-talk ;-) I ran mine with a cordless reversible drill and didn't really pay much attention to speed. I didn't go at it full bore as I was working on an already finished piece except for the hinges . . . which is where I broke the screw. The tool cuts smooth and quick . . . it did just what it was supposed to which can sometimes catch us by surprise, eh?
    Bill's tip is a good one, I picked up some steel screws from McFeely in the size I normally stock brass in. I always pre-run a steel screw now and haven't broken off a screw since.
    17,471
    also another vote for steel screws and learned the same way you just have.. also you can try to drill out the screw, insert glue and tooth picks and then rescrew if the drill bit is to big of a hole for you.. and another thing to get is the vix bit sets for predrilling there worth there weight in gold in my opinion..
    10,600
    I agree. I've used a set for years and they have saved me from the frustration of having the screw holes misaligned.
    13,357
    Oh yeah, learned the hard way on some small boxes to always use the steel screws first...
  1. A Broken Promise.
    Last Post: 11-07-2013, 10:19 PM
  2. HELP Broken tools
    By david swarat in forum General Woodworking Q&A
    Last Post: 12-01-2012, 03:49 AM
  3. My brain is broken
    By Leo Voisine in forum Off Topic Discussion
    Last Post: 04-07-2009, 09:31 PM
  4. something else i can't do with a broken arm
    By Dale Johnson in forum Handtool Project Showcase
    Last Post: 01-04-2008, 04:56 PM
  5. Broken band saw
    Last Post: 03-03-2007, 06:42 PM
