Results 1 to 5 of 5
Thread: Need Help Designing Large Table
    Mifflin County, PA
    7
    I need to put together a design/bid for a large conference table. It will be about 4' by 8' with a boat-shaped top and trestle-style legs. The customer wants a formica top with oak banding, legs and stringer.
    I'm in the 'design' process and am having a hard time wrapping my head around the idea of how to get the necessary structural rigidity and flatness to the top, which I am assuming I will do with the formica laminated to MDF. Should I be looking to some sort of torsion box design? Please help!
    jon, most wholesalers offer honeycombed substraight material just for this purpose in sheets up to 5x12........i don`t consider it to be a "high quality" product.....but for laminating formica it works pretty well.....you`d need to build your frame and use the honeycomb as a fill then laminate both sides but it makes a light, stable top.......if you go with mdf you`ll need to provide some way to keep it flat.....either with some type of frame underneath or by laminating both sides or both........by trestel are you talking about a 72"x24" pedestal or a single 16" diameter post? how thick can your top be? the base and top thickness are your major limiting factors......that and when building conference tables i try to make them where folks can sit on the edge without damaging the table......it happens .....tod
    What I would do...
    1 1/8" 45 lb density particle board laminated with plam both sides or plam and backer with urea resin glue, this is very stiff.
    Does a 1 piece 4x8 top clear all the doorways stairs elevators and what have you? I'd assemble the trestle on site.
    Good luck!
    Mifflin County, PA
    7
    Thanks for the good advice guys. The honeycomb idea is interesting, Tod. Do you have any brand names of this stuff that might help in my search? Thanks...Jon
    jon, i don`t ......i`ve never had cause to use it.......i saw it in a flyer from either paxton or hogan quite a few years back....sorry, tod
  1. Large wooden table top finish question ?
    By Dan Mosley in forum Finishing School
    Last Post: 02-19-2013, 01:45 PM
  2. John Economaki Designing
    By Dave Richards in forum Off Topic Discussion
    Last Post: 03-24-2011, 06:49 PM
  3. Communion Table & Stands - Large table done!
    Last Post: 06-03-2010, 07:30 AM
  4. Large Burl Table Finishing Question
    Last Post: 12-28-2009, 01:53 PM
  5. Building a large workbench/assembly table
    By Tom Clark in forum Flatwork Project Showcase
    Last Post: 05-31-2008, 11:35 PM
