Results 1 to 7 of 7
Thread: Seeking adhesive backed stencils?
    The Heart of Dixie
    4,268
    I know somewhere out there someone knows a company that makes these. I want to have some stencils cut on an adhesive material that I can apply, paint and then peel the stencil off. I have Googled everything I can think of but I have yet to find anyone making (cutting) these but I can find the materials to make my own.
    Anyone help me?
    Custom built boats and Kits
    2,784
    What about using the spray adhesive the decorators use when using stencils to paint objects on a wall? Spray it, stick it, paint it, pull it up, go again. Would work even better on a non textured surface. Jim.
    edit: What about the vinyl sign/lettering companies? They would just have to peel off the object and leave the background. Just opposite of what they usually do.
    Coolmeadow Setters...
    Exclusively Irish!
    13,357
    You'd think it would be easier to find? I just renovated my honda motor. The paint had peeled and I ordered some vinyl decals online to restore it.
    Maybe talk to a vinyl sign/decal maker? Not sure the decals would work so good as the surface is very flexible, but they ought to be able to cut something out of some sticky material.
    Alternatively, you could make your own stencils and use a low-tack adhesive to hold them on while you paint?
    The Heart of Dixie
    4,268
    I have to go back to the sign shop and I am going to ask him to look into it assuming he doesn't have something.
    I can't use a mylar stencil. Can't make the shapes I want. There are center pieces so it needs to be stick on.
    13,357
    The decals I got come in 3 layers. A wax backer, the decal, and a clear cover.
    You remove the wax backer, soak things up, position it, and squeegee it. Then a little later you remove the clear cover, which keeps everything in place.
    Just an fyi...
    5,319
    Almost any sign shop can make the vinyl stencils for you. It's just about all they use for truck logos, etc. anymore.
    My daughter has one of those Cricket Scrapbook cutter machines. She can cut most any shape. And there is an adhesive backed material that you can obtain... Check that out.
  1. Recommended Spray Adhesive?
    By David Agnew in forum General Woodworking Q&A
    Last Post: 01-25-2015, 05:06 AM
  2. Laminate adhesive
    By Guy Bratt in forum General Woodworking Q&A
    Last Post: 03-11-2013, 06:32 PM
  3. Spray adhesive?
    By Julio Navarro in forum General Woodworking Q&A
    Last Post: 01-21-2013, 03:38 PM
  4. Proper adhesive
    By Rex Bloem in forum Jigs and Fixtures
    Last Post: 01-18-2013, 05:25 AM
  5. Spray on Adhesive that lets go when done...?
    Last Post: 02-22-2007, 11:48 AM
