Results 1 to 4 of 4
Thread: Olive wood Vessel
    Palm Springs, Ca
    1,169
    Olive wood Vessel
    Had the day off and worked in the shop for a bit - I took out of soak a Olive wood vessel I turned 3 days ago. Below are pictures of the vessel out of soak and drying inside the house now in the open.
    Im thinking of several coats of Formby's Tung Oil - letting dry for a week and buffing with WD and hand wax with Renaissance.........
    It is a very easy wood to cut but you have to control the drying along the way because it will crack easy - as you can see in the picture I did not keep it wet and in a couple areas it cracked while i was hollowing - The next one I did after this one I kept it wet with spray bottle until i was finished with the cutting and I didnt have any cracks (that one is now soaking)
    On both of them I sanded thru the grits until I reached 180 - then soaked for the 3 days and wet sanded thru 600 today - wiped down well and inside to dry now..............................
    Attached Thumbnails Attached Thumbnails P1010036.jpg   P1010037.jpg   P1010038.jpg
    30,014
    Dan, I took the liberty of moving this post from Steve's pecan hollow form thread. I'm guessing that you intended for it to be a separate thread.
    Looks pretty good so far.
    Palm Springs, Ca
    1,169
    oooops..............yeah.......thanks for correcting it
    Los Angeles, CA
    2,668
    Yeah! so far so good. Looking forward to see the final product.
  1. More pens using Bethlehem Olive Wood
    Last Post: 05-17-2013, 08:07 PM
  2. Olive Wood Projects - New Anchor Seal ?
    By Dan Mosley in forum Lathe Project Showcase
    Last Post: 09-12-2010, 05:14 PM
  3. Olive Wood and processing
    Last Post: 09-05-2010, 01:55 AM
  4. olive wood and African blackwood box's
    By George Watkins in forum Lathe Project Showcase
    Last Post: 10-05-2009, 12:11 AM
  5. Olive Wood Bowl
    By Bernie Weishapl in forum Lathe Project Showcase
    Last Post: 04-21-2009, 06:01 AM
