Results 1 to 10 of 10
Thread: Cyclone Overfill - Guess It Was My Turn
    9,077
    I was always wondering when this would happen to me. I try to pay attnetion. I didn't think I had done that much work since the last dumping. I caught on when I saw material in the bag under the filter; this is usually empty. . . doh!
    Constantine, MI
    7,892
    BTDT - Last week.
    www.wrworkshop.com
    BTDT so many times it is starting to become SOP (Standard Operational Procedure)
    Now, lets see you empty w/o cascading all over the floor...
    12,264
    Well Glenn i saw Oneida Air came out with a new dust bin gadget. For all of you take a look here this is an upgrade you might want to consider.
    It's not REALLY overfilled unless it was physically impossible to take the lid off without a couple gallons of sawdust spilling on the floor.
    15,808
    You have got to be freaking kidding me, $129 for THAT
    Holy cow, just put a window in your lid and "LOOK" and see if it is full or now...... this is NOT rocket science
    12,264
    Yeah but "that" helps the gray hair syndrome of remembering to check. It lets you know its happening automatically.
    If you look at it they using a proximity sensor and that is where cost comes in. Its not a gimic.
    Wonder if a simple Micro switch gezt the job done? Wit a paddle attached, when the mass builds up it activates a light...
    Or place a bathroom scale under the bag, (or canister) when the weight reaches a certain amout, its time to change.
    15,808
    Do you forget to turn on the lights when you go into the shop?
    Do you forget to use hearing protection and safety glasses?
    When I get set to run a tool that uses the cyclone I walk all of 10 or 12 feet (max) to the cyclone, bend over just a bit and "look" into the window......
    if it is full, time to empty it, if it is NOT full, return to machine and cut stuff.
    Next thing they will come out with a gizmo that sends you a text message if your cyclone bin is full, or calls your wife and gives her a recorded message.....
    Sorry, I can think of a LOT more things that I'd spend the money on.
    Now, if your cyclone is outside in a shack well, that is a very different thing, checking it would not be easy, so the sensor would be good for that, but if you cyclone is in the workshop.....
    My opinion mind you, YMMV
    9,077
    My barrel-to-cone hose is clear and should have been easily spotted. I do have the tendency to get "overly focused". Doh!
  1. Cyclone Clog...?
    Last Post: 04-03-2016, 11:12 PM
  2. Replies: 24
    Last Post: 07-04-2014, 02:04 AM
  3. DIY cyclone seperator
    By Brent Dowell in forum Jigs and Fixtures
    Last Post: 02-26-2014, 10:01 PM
  4. cyclone
    By Jiggs Elphison in forum General Woodworking Q&A
    Last Post: 11-24-2009, 10:46 PM
  5. Shop Vac cyclone
    By Alan Bienlein in forum Jigs and Fixtures
    Last Post: 11-12-2009, 01:30 AM
