Results 1 to 10 of 22
Thread: Warning - Rant
    Constantine, MI
    7,891
    Warning - Rant
    Why is it you can spend $60 on a sheet of paint quality birch ply from an otherwise reliable lumber dealer (not borg) and still not get something that will lie flat?
    Rant over.
    www.wrworkshop.com
    Nov 2008
    outside of Toronto, Ont
    183
    Improper storage.
    Constantine, MI
    7,891
    Quote Originally Posted by Paul Brubacher View Post
    Improper storage.
    They were stored flat in their warehouse. I noticed a little curve when I bought it, but I figured I needed only half the sheet so I would be OK. NOT
    www.wrworkshop.com
    Indianapolis area
    1,697
    Moisture???
    ________
    Ron
    "Individual commitment to a group effort--that is what makes a team work, a company work, a society work, a civilization work."
    Vince Lombardi
    Oct 2009
    Dennison, MN
    512
    its plywood? If you want flat use MDF or MDF cored materials. I hate the stuff, but it does have its applications, (mdf that is).
    "Do, or do not. There is no try."
    -Yoda
    Dec 2008
    falcon heights, minnesota
    5,610
    if you noticed it before you bought it, and bought it anyway, no cause for a rant.
    benedictione omnes bene
    www.burroviejowoodworking.com
    Central NY State
    3,374
    I once bought several sheets of cherry ply, like Rennie, from a local plywood dealer, with whom I had done business for years. Each sheet, IIRC was about $90. I built a floor to ceiling unit, and upon applying finish [Watco] found a 1/8" wide gap in the substrate just under the veneer. It absorbed the finish very differently, and left an ugly mark across the piece. Unfortunately, I discovered this after the piece was assembled. Glued, biscuited, solid. What a headache.
    Anyway, I did go back to my vendor, with a piece of the defective sheet, and received a refund for the sheet, but.....
    Rennie, feel free to rant.
    The Heart of Dixie
    4,268
    Why
    It's a sign of the times. Dollars over quality. I see it a lot of stuff. I can't find decent boat building lumber anymore. Clear wood? Yea right.
    Custom built boats and Kits
    Constantine, MI
    7,891
    Quote Originally Posted by Dan Noren View Post
    Harsh But true - although it was a minor amount it seems that, once removed from the 'movement restricting stack' it found the freedom too much to handle and went wild.
    Quote Originally Posted by ken werner View Post
    Not likely I will get a refund, but not likely they will see many more of my dollars either.
    Can't argue that!
    Karl - these will become interior shutters, 23" wide and 58" tall, attached to window casing with a 48" continuous hinge (it's what the customer wants). I don't want to chance screwing a hinge into the edge of an MDF sheet or core. I'll be heading out to my hardwood supplier later today for a 5x5 sheet of 12 ply 3/4" baltic birch. I hope to have better luck with that - and my dealer will sort through the pile with me looking for the best sheet.
    www.wrworkshop.com
    4,552
    Got one better than that I had to build fireworks display shelving for a large Fireworks mega store a few years back and used paint grade maple ply. I build all the cabinets (several used full sheets) and primed them and all was good until I put the top coat on and that were things went BAD. The finish dried and parts started to washboard and what I found is they had put a wood filler in the edges of the plywood to cover up the gaps in the cove veneer the gaps started at 5/8 on the edge and would go up to 12 in the middle of the sheep. Found one that was almost 3' wide. I had cut out and bondo all the voids. Called my supplier and he sent out new plywood same thing. They flew a guy from the plant in Washington state to see what the problem was. He said they were allowed a 1/2 gap under the face veneer and I told him I could deal with that and check them out that when he measured every sheet and the closet her came was the 5/8 one.
    Then he asked me what I expected from the plywood I asked him if it was paint grade and he said yes and I told him then I expected to be able to paint it.
    They replaced 9 units of this stuff and what they brought me was the same.
    I had to buy Bondo by the gallons to fix the problem as I was running out of time they said the would cover cost but when I turned a bill in for $22,000 for extra labor and cost to me redoing things the backed up and said no way.
    My attorney made them eat the cost of 9 units of ply in the end thats over 335 sheets.
    A Turn N Time
    Frog Pond Guitars
  1. Home Depot Canada....rant warning.lol
    Last Post: 04-24-2016, 11:52 PM
  2. Okay This is My Rant!
    By Paul Douglass in forum Off Topic Discussion
    Last Post: 12-12-2013, 09:12 PM
  3. Had to rant
    By Jim Burr in forum General Woodturning Q&A
    Last Post: 09-07-2013, 06:58 AM
  4. I need to rant
    Last Post: 10-28-2011, 04:26 PM
  5. Rant of the Day
    Last Post: 02-10-2010, 07:17 PM
