Results 1 to 10 of 17
Thread: Is a root ball turnable?
    May 2009
    Lafayette, Indiana
    2,380
    I helped my brother pull some shrubs from my parents home this weekend. These had been planted about 40 years ago. When we got them broke loose the color of the base was fantastic. Is this usable? I brought two of them home with me and hosed off the dirt. Each base is about 6-7 inches across and about 8-10 inches tall. do they need to be sealed? or can I turn them now???
    Tom
    Sep 2007
    Plainwell, Michigan
    4,857
    Me not being a turner can even answer this one....YES there have been many awesome root ball turnings shown here. I am sure Vaughn and others will jump in and show you examples
    Yup
    I'm a novice turner so I can only give you my limited advice.
    "Grip it and rip it"
    With color like that I'd try even if the results were horrible.
    Nope. Can't be done.
Name:	Myoporum Bowl 1- 01 800.jpg
ID:	49322 Click image for larger version.
Name:	Ralph's Root 1 - 800.jpg
ID:	49324 Click image for larger version.
Name:	Ash Root Ball Bowl 2 - 01 800.jpg
    They are a challenge for sure, but the results can be pretty cool.
Name:	Bowl 19 - 04 800.jpg
ID:	49325 Click image for larger version.
Name:	Bowl 043 - 01 800.jpg
ID:	49326 Click image for larger version.
Name:	Bowl 058 - 02 800.jpg
    Sharp tools, light cuts, safety gear, and caution are you need. I also like to pressure wash the roots before I get into them with the chainsaw or gouges. You'll still likely hit some rocks or other hard stuff, but the more you can wash away, the better.
    May 2009
    Lafayette, Indiana
    2,380
    Vaughn, thank you for that. Your finished product is amazing! Is it suggested that it dry out first?
    3,132
    Tom i agree with Vaughn can't be done. Send them down here and i'll throw them away for you.
    This is the only one i've done so far and it was bradford pear.
    Steve
    Quote Originally Posted by Tom Baugues View Post
    Tom, the ones I've done so far have been somewhat wet when first turned, so I roughed/dried/re-turned them about the same as I would any other wet wood. I've got another big myoporum root in my woodpile that was cut three or four years ago, so I'm guessing it's pretty dry by now. As soon as I work up the motivation (and courage) to turn it, I'll find out if dry is better than wet.
    May 2009
    Lafayette, Indiana
    2,380
    Stephen, that piece is stunning to say the least. I can only dream.
    Goodland, Kansas
    4,834
    Tom I have turned a couple that were green. One thing you have to watch for are impediments such as rocks when turning. The ones I did had a couple imbedded in them.
    Bernie W.
    May 2009
    Lafayette, Indiana
    2,380
    I decided to put the smaller of the two on the lathe tonight to see what would happen. The wood inside is really wild. At first I just turned it down to see what it looked like then it cracked off a large chunk in the center so after turning it down this is what I'm left with. Now I have no idea where to go with this. It looks like a goblet but the base would not be large enough to support it. So now I'm thinking of using the "large end" for one project and use the "stem" for something else???? I just don't know what???? Anyone want to give me any ideas?????
    Tom
  1. crab apple root ball
    Last Post: 07-16-2010, 12:16 PM
  2. How long does it take to turn turnable?
    By Tom Baugues in forum General Woodturning Q&A
    Last Post: 05-12-2009, 01:19 AM
  3. Ash Root Ball Bowl...Finished
    Last Post: 03-04-2009, 03:27 PM
  4. Can someone ID this tree please and do I want the root ball?
    By Mark Rios in forum Off Topic Discussion
    Last Post: 07-23-2007, 05:28 AM
  5. Myoporum Root Ball Bowl
    Last Post: 05-11-2007, 04:45 AM
