Results 1 to 10 of 26
Thread: New wood stash and drying wood
    Central PA
    638
    I am borrowing my inlaws Lucas Mill portable sawmill for a few months so I cutting up a storm right now. I cut down 5 trees last saturday and I am cutting them into boards as I have time. Here are some pics. I cut up 3 beech logs(1 tree) and 1 sugar maple log. I don't have pics of the maple but its nice, there is some spalting in it, or maybe its just staining where bugs went in the log in either case it will make some nice stuff. Here is where my drying question comes in. I want to make a snare drum out of some of the maple but right now its really wet. I was planing on air drying the wood but I would like to use some long before its dry. I have heard something about being able to dry wood in the oven. Does anyone have any experience with doing that. I don't need big pieces so the would fit in the oven.
    Attached Thumbnails Attached Thumbnails Sep15_0001.jpg   Sep16_0001.jpg   Sep16_0002.jpg   Sep17_0001.jpg
    Palm Beach Gardens, Florida
    185
    Hi Dave,
    Wood (pun intended) you have any offcut chunks from the beech? I would like to make a few planes and some handles.
    We don't grow American Beech here in south Florida!
    Regards,
    Bill Antonacchio
    Central PA
    638
    Quote Originally Posted by Bill Antonacchio View Post
    Hi Dave,
    I do, but they are not very big, what size are you looking for?
    185
    Lightbulb
    Hi Dave,
    Since USPS says:
    Priority Mail Medium Flat Rate Box (FRB2) $10.70 13-5/8" x 11-7/8" x 3-3/8"
    How about:
    1 @ 18" L x 3.25" W x 3.25" H
    2 @ 12" L X 3.25" W x 3.25" H
    x @ x" L X 3.25" W x 3.25" H
    or what would fit in the box.
    Regards,
    Bill Antonacchio
    North West Indiana
    6,099
    Dave, depending on the size/amount of wood wanted dried soon, a solar drier? Some sort of box, metal, painted dull black on inside, glass pointed towards sun at longest period of the day, measure inside high temps and see what you get, keep a record on moisture of the wood. Gets to the point you can use, remove and acclimate to the area you are going to use it in.
    Jon
    The best way to dry it yourself, or perhaps I should say the "Easiest" way is just air dry it. Stack it where it gets good air movement, but not direct sunlight, the tops and sides of the stacks can be covered, but not the ends, to allow air to move. make your stickers 3/4" square, and place them every foot, make sure the stickers all line up with the one above and below it. Put some weight on top of it, does not need to be that much.
    The whole solar kiln is actually quite complex to do it right, you have to have heat from the sun to raise the temp in the kiln, this will make more water from the wood evaporate, but then, when it gets to a certain high humidity, you have to exchange the air in the kiln. Take the hot humid air out, replace it with cool dry air, close it up and start again, that is how a solar kiln will more quickly dry out the wood. The problem is if you do this too fast, the wood will check and crack, if you do it too slow, you will get mold. If you really, really need the wood in a hurry, find a local wood supplier who will rent you space in their kiln on the next run, otherwise, I'd advise to just air dry it and wait.
    Nice looking wood for sure!
    11,833
    Agree/disagree about the solar kiln. Do searches, the design can be very simple. What is essential are a couple small fans to keep air moving.
    Not said, do seal the ends, preferably with Anchorseal.
    Congrats on the big haul.
    Central PA
    638
    Hi Dave,
    Since USPS says:
    How about:
    I don't have anything 3x3. When I was cutting up the log if I couldn't get a full board out of a section I cut stickers out of it. Sorry
    Central PA
    638
    I am going to air dry most of the wood but I am anxious to make a snare drum out of some of the maple. If I cut the board into 1' sections could I put them in the oven to dry them, I am sure I read somewhere about drying small pieces in an oven, but maybe it was just to do the old school moisture test
    Dave, what are the dimensions of the wood you plan to use for the snare drum? Are you gluing up staves or turning it out of a solid piece?
  1. Wood curing/drying question...
    By John Pollman in forum Off Topic Discussion
    Last Post: 03-10-2011, 06:40 AM
  2. Wood Drying Kiln
    Last Post: 12-18-2008, 03:11 AM
  3. Worked Out at the Wood Stash Site
    By Jon Lanier in forum Lathe Project Showcase
    Last Post: 08-08-2008, 06:57 PM
  4. Wood Drying Technique Needed
    Last Post: 08-02-2008, 03:09 PM
  5. drying wood in wax
    Last Post: 03-22-2007, 03:32 AM
