Results 1 to 4 of 4
Thread: How do I correctly size base board & crown mouldings
    Sudbury, MA
    38
    Unhappy How do I correctly size base board & crown mouldings
    Hi All,
    I am ready to start finish carpentry on our renovated bathroom. The room is small with about 5'x7' of floor space with 7' ceilings not including the tiled tub area. My wife and I would like to use crown moulding, but are unaware of how to size it to the room. Obviously a 6" crown would look silly, but would a 1 3/4" crown look too small?
    Our house has classic 3 1/2" colonial baseboard profile should we stick with that for continuity or can we use 5" with an interesting cap? Door and window moldings are 2 1/4 colonial profile which we intend to stick with.
    Thanks for your help.
    Cheers,
    Nick
    "A foolish consistency is the hobgoblin of little minds"
    13,452
    the 1 3/4 might be a bit small, you usually want it larger than the door trim to stand out, but that's a pretty low ceiling. If you do go with that small, one trick is to add some picture moulding about 6" below the crown as another feature to make it look less "alone". I've also seen it done that way but everything from the picture moulding up was painted the same trim color, creating a cap around the room.
    Sep 2010
    Nepean,Ontario,Canada
    24
    go with the same size crown as the base boards size
    Floydada, Tx
    1,941
    I would not go with anything bigger then 3-1/2". If you do it will pull the ceiling down lowr then it already is. You can use the full size base to tie into the rest of the house.
  1. Mouldings in Practice Class @ Port Townsend
    By Bill Satko in forum Handtool Project Showcase
    Last Post: 08-11-2015, 03:41 PM
  2. Vertical Chest Board and Chalk Board
    By Jeb Taylor in forum Flatwork Project Showcase
    Last Post: 02-25-2012, 10:56 PM
  3. Full size Drill Press mobile base
    By Don Taylor in forum General Woodworking Q&A
    Last Post: 11-10-2007, 04:54 AM
  4. Miter Saw Crown Jig
    By Steve Clardy in forum Jigs and Fixtures
    Last Post: 12-09-2006, 01:48 AM
  5. back cutting small radiused mouldings on the shaper
    By tod evans in forum Jigs and Fixtures
    Last Post: 11-10-2006, 05:44 PM
