Results 1 to 10 of 16
Thread: I paid too much...
    Oct 2009
    Dennison, MN
    512
    I paid too much...
    but its mint.
    purchased new in 2000. Looks to be one of the last US built PM66's. I have an 04' as well, and its a lump-O-poo so hopefully this one is better
    "Do, or do not. There is no try."
    -Yoda
    17,472
    what was wrong with the 04 karl? shortened version is fine
    Oct 2009
    Dennison, MN
    512
    Constant motor issues. Eats up brushes every two years or so. Tilt and height adjustments suck despite adjusting everything every which way, and lubing the heck out it. (which straight grease has been the most effective, and longest lasting) Also has a cheap switch, hasn't failed yet, but feels poorly made. Oh and a big c-clip slipped off of one of the shafts causing the whole trunnion to slip to the right. Took a while to figure that one out.
    Just unloaded the new/old one at the new shop.
    Riving knife/guard for sale, plus the mobile base.
    -Yoda
    12,256
    Karl excuse my stupid question but is the brushes being eaten up not a function of the motor. If you changed the motor surely that would go away.
    I didn't know that the PM had a brushed motor. I do have some experience with brush type motors and depending on how many hours a day the motor will run will dictate the brush wear. Also the amount of load on the motor. Brushed need to be under load in order to commutate properly so if the saw is run without any load (not cutting) this will shorten brush life). I could go on and on about causes of shortened brush life but it would be futile. Let me say that the use of a brushed motor in a table saw is a waste of money.
    Oct 2009
    Dennison, MN
    512
    sorry, not brushes. Points or something, (that doesn't sound right either)? I don't know. It starts having trouble starting, I grunt the motor out take it to the repair place, they fix it, couple years later I do it again. I've done that three times in the six years I've owned the other saw.
    Plugging something in is the full extent of my electrical knowledge, beyond hitting the start button or pulling a trigger.
    -Yoda
    wish I could drop buy and help you with the problem. but it a long drive. could the points be on the starter ?
    Feb 2009
    Whittier, CA, USA
    512
    Points might be capacitors.
    I hope you get all you expect out of your new saw.
    Cheers,
    Dan Gonzales
    Whittier, CA, USA
    Dona nobis pacem
    30,017
    That's a nice new/old saw, Karl. I hope it serves you well. I'm guessing you put a lot more wood through a saw in an average week than most of us run in a month or three. Based on your experience with the '04 model, I wonder if the PM line has trended more towards the high-end consumer market instead of the low-end pro market. It seems like several brands (Delta and PM come to mind) started heading that direction about 5 to 10 years ago. Out of curiosity, have you seen or heard of any other pros like you running into similar problems with newer PM66s or Unisaws?
    5,321
    Quote Originally Posted by Dan Gonzales View Post
    Points might be capacitors...
    Or it could be the contacts in the centrifugal switch to the start windings.
  1. She gets what she paid for...
    By Ken Cook in forum Flatwork Project Showcase
    Last Post: 12-25-2013, 07:03 PM
  2. I Got Paid!
    By Dave Richards in forum Off Topic Discussion
    Last Post: 04-12-2013, 03:32 PM
  3. Getting paid to turn?
    By Dale Johnson in forum General Woodturning Q&A
    Last Post: 03-06-2009, 05:23 AM
  4. Paid moderators on forums?
    By Al killian in forum Off Topic Discussion
    Last Post: 01-29-2008, 10:27 AM
