Results 1 to 10 of 17
Thread: Top dead center compression stroke Help!
    Aug 2008
    Under MI thumb
    56
    A few weeks ago I blew a head gasket in my blazer. Due to lack of funds I have undertaken the job of rebuilding the top half of my vortec v-6. I am nearing the stage of installing the distributor and the shop manual says I need to position the crank so I am at top dead center on the compression stroke of cylinder #1. Are there any mechanics in the family that can tell me how I determine this position? Can somebody help me turn my garage back into a woodshop?
    Victor
    A picture is worth a thousand words.
    A video is worth a thousand pictures.
    Experience is priceless.
    Apr 2009
    Outside the beltway
    5,250
    Quote Originally Posted by Victor Skellett View Post
    Sorry Vic I can not help you. It's been to many years sense auto shop class in HS.
    ::: Andrew Wyeth :::
    colonialrestorationstudio.com
    Melbourne, FL
    472
    TDC
    Look for timing marks on the front end of the crankshaft.
    Should be a mark and a tab for TDC and maybe some timing marks with +- 5/10/15 degrees
    Apr 2009
    Outside the beltway
    5,250
    Pete I remember that now LOL, as I tell my son Jarrod I have forgotten make then You will ever imagine.
    13,427
    I believe with the valve cover off the drivers side, and spark plugs removed, you should see the intake valve close and then feel the piston top out on the stroke for cylinder #1, this should be Top dead center.
    A good place that I use is for vortec advice is: http://www.chevytalk.org/fusionbb/sh...p?fid/78/fp/1/
    The guys on that site are always very helpful.
    Additional info: There are two TDC, compression stroke and exhaust stroke, this is where I mentioned that the intake valve should just be closing and then the piston will be coming up for it's compression stroke. You can also use a straw or dowel and mark it as it comes up to determine where it reached the top at. Just don't use something that will break off in the cylinder.
    North West Indiana
    6,097
    Darren is right on, with the valve cover off, you can see the pushrods/lifters. On top dead center of compression stroke the piston is compressing the fuel air mixture in the cylinder, at TDC the plug fires igniting the mix pushing the piston down (power stroke now). Next time up is exhaust stroke because the exhaust valve is open and the upward motion of the piston is pushing the burnt fuel/air mixture out. At TDC then the exhaust valve closes and intake valve opens, piston goes down sucking in (kind of like inhaling hence intake) the new fuel/air mixture, at bottom dead center the intake valve closes (exhaust valve is still closed) compression stroke is beginning, at TDC the mixture gets ignited again. Thus you need to identify which cylinder is #1, find both valves for that cylinder and when the piston is at the top of its stroke and both valves are closed, you are at TDC on compression stroke. By the way, that is the four strokes of a four cycle engine! Good luck, can be an intimidating task, but man will it make you feel good when it is done and you saved all that money! Hope this helps.
    Jon
    What Pete, Darren and Jonathan said is right on the money
    One more point, take the spark plugs out when you do this, MUCH easier to turn the motor over by hand with them out
    Sep 2010
    Woking, Great Britain
    22
    Then use a little stick or straw to determine the tdc
    also PLEASE NOTE which is cylinder one, i think they count from the cabin
    Aug 2008
    Under MI thumb
    56
    Thanks everybody! With your help I found the correct position last night and in a little while I'll install the distributor. Thanks again!
    Victor
    13,427
    I look forward to seeing how all goes for you. I just had the upper intake off of mine to change the fuel regulator, boy what a pain. Had to literally remove the upper wiring harness to get the thing off. Still have my main issue with it cutting out, but it did fix one of the symptoms I was having. I only had 53 lbs of pressure when it was suppose to be 55 - 65, at least it's back in that range.
    Good luck!
  1. My wife, Myrna, had a stroke last night
    By Jim C Bradley in forum Off Topic Discussion
    Last Post: 12-18-2013, 05:23 AM
  2. My Wife's Stroke
    By Garry Foster in forum Off Topic Discussion
    Last Post: 11-01-2012, 03:42 PM
  3. Mom had a stroke
    Last Post: 03-23-2012, 03:30 AM
  4. Inexpensive safety center/dead center
    By Mike Mills in forum Turning Tool Questions and Show & Tell
    Last Post: 01-25-2012, 11:50 PM
  5. Health/ indications of a blood clot/ stroke
    By Robert Schaubhut in forum Off Topic Discussion
    Last Post: 07-19-2009, 03:07 PM
