Results 1 to 10 of 16
Thread: What do you have for a band saw base cabinet?
    Long Hill Township, NJ
    467
    Hello All -
    I have been circling around my garage and one of the minor annoyances is my band saw base and the mobile base underneath it. I have a Grizzly G0555 with the open base. I put an HTC mobile base under it and just never liked the setup. I don't like the "step on to lift" feet and the small wheels.
    Additionally I'm not comfortable with the table height. I'm 5-7 and the table height is right at chest level on me and it feels too high. I want to lower things about 6 inches.
    I've decided to build a 2 or 3 drawer cabinet on standard double lock casters. I used 4" double locks from Woodcraft for my table saw base and like them a lot. Should I go with the 4" again or go with the 3" DL casters? Any other caster suggestions?
    If you did a cabinet what did you like/dislike?
    Cheers
    Jim
    Last edited by Jim Mattheiss; 10-02-2010 at 08:15 PM. Reason: change ts caster sizes
    Dec 2008
    Santa Claus, In
    4,779
    Jim, I am going to build a base for mine as well. Just don't like the loss of room the factory stand provides. I am going to use 3" DL casters and all the drawers I can fit. Thinking about a 3/4 back to help with racking.
    11,825
    Show progress pics. I might be able to steal.....er....borrow your ideas for my 0555.
    I have been thinking about a cabinet big enough to put my Shop Vac. Currently it just sets next to the saw and takes up my limited shop space.
    May 2009
    Syracuse, Nebraska
    669
    My stand is still in progress, no pics for awhile, recovering from surgery. I off set the casters on an ell bracket so the whole thing would be lower. Lost about 8" in width for foot print on the floor but the wider wheel spacing seems a lot more stable. According to my plans the final height will be around 44-46 inches.
    I haven't fitted any drawers yet. They will be custom made to needs of the project. Also put peg board on the sides since the casters are eatin' floor space anyway.
    5,533
    see that green box in the lower left hand corner, that's about 150 lb of MDF plus a couple of Bricks inside... previous owner of my BS decided the stock HF stand was too wobbly, so he used the Larry rule of 'when in doubt, build it Stout'... takes two strong young men and a crane to move it (or me, when I need to). on the plus side it makes the saw reallllllly stable. I just have to be careful when I choose to relocate it.
    -Ned
    Dec 2008
    falcon heights, minnesota
    5,609
    this is what i have both my bandsaw (from grzzly, and just a half step down from yours, model-wise). i built this bench specifically for the bandsaw and drill press, and used 4" casters. it's very handy, and nice to just wheel out into the driveway, and work outside on sunny days like today. the spacer on the bottom can be widened to accomodate a cabinet, as i had done with the lathe platform. i thought i had a pic of the drawers, but i don't, but you can see the space available. best thing about these benches, are they are cheap to make, and can be altered to what ever height, depth, and width you want.
    Attached Thumbnails Attached Thumbnails new set up bandsaw.JPG   19 all set.JPG
    benedictione omnes bene
    www.burroviejowoodworking.com
    467
    Dan - I never considered combining tools onto a single cart . . . I have a Grizzly 13" Planer on a stand alone cart. I need to think that thru - I might be able to gain back some space doing that - assuming the geometry / access works for both machines.
    Thanks everyone for the input . . . I'll be posting more as things develop.
    Cheers
    Jim
    Whatever you deside to do, may I suggest you make it ridgid. Vibrations are conveyed through the base and can sometimes enhance the effect. I read an article on tuning up a BS and one of the suggestions was to top off the metal base with a thick wood top. The saw is bolted to the top as well as the motor. Although I thought the base seemed sturdy, I had a slab of 8/4 Maple needing a use, being just the size of my base top, I decide to give it a try, and sure enough, it smoothed out what I thought was normal for a 14" saw. No other variables, just the thick top absorbed and damponed the flexing of th base top.
    Just a suggestion and a thought to keep in mind when you design your base.
    12,247
    This is what factored into my bying a totally enclosed base bandsaw however i have also thought about doing exactly what Bill has mentioned. Having been exposed and worked in the vibration monitoring field on heavy machinery, its not only the aspect of vibrations moving all over the show but they also have their effect in wear albeit on our small machines it aint gonna be huge. But we learn every little bit counts just like moving from 1/4 inch router bit to a 1/2 inch. If it was not significant we would not do it right?
    Thanks for the thread Jim. BTW which mobile base you got that you dont like?
    With your base as is you could always consider chopping it down and covering the side in some plate which you could hold on by self tapping screws. That would add weight and dampen the whole saw as well as then have it at the lower height. To me the deal breaker here would be your existing mobile base.
    North West Indiana
    6,097
    Wow, I can't believe how far behind I am in posting on my shop thread.
    Here is what I did to my band saw and it is still there. For making pens, this corner table has been super at saving time. I have my small belt sander on it for sanding tubes, bandsaw for cutting blanks, next corner is drill press for drilling and then facing blanks and turn 180 degrees and my lathe is there on the wall. Here is the last picture (about 1/2 way down I think next to last picture)
    http://familywoodworking.org/forums/...=15101&page=28
    I am going to have to get some pictures and catch that up.
    Jon
  1. First Band Saw Box
    By Royall Clark in forum General Woodworking Q&A
    Last Post: 11-03-2014, 08:03 AM
  2. Narrow base cabinet door design
    Last Post: 01-25-2009, 02:56 AM
  3. Cheap base cabinet ideas?
    Last Post: 03-27-2008, 07:52 AM
  4. Old Arn - Band Saw
    By randy street in forum Old Iron
    Last Post: 08-17-2007, 12:45 PM
  5. Tablesaw Base Cabinet--Wild Hair Idea
    By Dave Richards in forum General Woodworking Q&A
    Last Post: 03-03-2007, 04:25 AM
