Results 1 to 4 of 4
Thread: Plane angle?
    Oct 2008
    Upstate S.C. near Anderson
    26
    Plane angle?
    Planning to make a scraper plane using wood for the body. I'm thinking just a little bit of angle, but what angle should the blade be? I believe that most any hardwood will work: I have plenty of pecan and cherry. Are there some websites that have simple plans? Thanks!
    Jim Evatt
    May 2008
    Bellevue, WA
    38
    Check the Popular Woodworking Magazine web site (http://www.popularwoodworking.com) and do a search for scraper plane plan. I've seen the plan in the long ago past, well maybe 2 years back.
    Dick
    5,321
    For a scraper, you'd want a slight back angle - probably somewhere around 5.
    I'm guessing what you want is to sort of emulate the Stanley #85. Patrick Leach's Pages give a pretty good description to use as a starting point.
    12,251
    Jim
    You can get a blade here for $5 with the correct angle already on it. Use the dimensions of the Stanley #80 and you are away. Good luck.
  1. FS: Sargent std angle block plane - $25
    By ken werner in forum Classified Ads
    Last Post: 08-21-2012, 04:23 PM
  2. WoodRiver Low Angle Block Plane
    By Matt Hutchinson in forum Neander Woodworking Q&A
    Last Post: 03-08-2011, 05:20 PM
  3. Lee Nielsen 60 1/2 low angle block plane - SOLD
    By Mark Rios in forum Old Ads
    Last Post: 11-18-2008, 05:35 AM
  4. Replies: 7
    Last Post: 07-15-2008, 10:12 PM
  5. Replies: 0
    Last Post: 07-02-2008, 08:24 PM
