Results 1 to 4 of 4
Thread: Last Phase Hollowing Rig
    Palm Springs, Ca
    1,169
    Today i fiinished up the little things and tried the rig out on a much larger pc of olive wood. I took off the safety stops and wired up the laser to test it out (5 volt laser from Laser Land). The log is 15" long and 12 1/2" wide.
    I drilled a deep hole with a old bit I had by welding in a pc of drill rod (see picture #1).
    I hollowed as usual by hand for awhile and then setup the rig as shown in the pictures below (pictures 2-5) . It cut great until i got about 2/3 of the way into it and then it started acting very jerky. I tried raising up the tool rest but it didn't seem to work and then tried rotating the cutting tip down slightly - didn;t help either... I had to reposition the cutter several times due to the jerking tork that the tool was getting.
    What im wondering is if I should have made the cutting tips so they just solidly mount into the 3/4" round bars instead of the adjustable one ive been using (picture 6). Like taking the bar steel and putting a 45' hole in it with a set screw to hold the cutter and I could do the same for a straight tool...........thoughts ??
    Anybody have any other ideas ????
    thanks Dan
    Attached Thumbnails Attached Thumbnails Drill-Bit.jpg   Sunday-1.jpg   Sunday-2.jpg   Sunday-3.jpg   Sunday-4.jpg
    I'd make at least one more tool holder for it, drill at a 45 and make that holder straight, no goose neck, make it thicker steel even if you can get some. Mine are, IIRC, about 20mm in diameter which is just over 3/4" and I have not had a problem with them.
    Jul 2007
    Des Moines, IA
    854
    I will chime in. Stu has some good advice. I have even used some 1" bar for my snake. Especially when you are reaching over the tool rest a ways.
    30,017
    Looks like it works good, Dan. Ditto on the previous advise about bigger boring bars and the need (or lack thereof) for the bigger bars to be goose necked.
  1. 200V Three Phase to 200V Single Phase....?
    Last Post: 02-09-2014, 01:18 PM
  2. 3 phase table saw motor to trade for single phase
    By Robert Schaubhut in forum Classified Ads
    Last Post: 03-07-2013, 04:21 AM
  3. Phase III dresser
    By Alan Bienlein in forum General Woodworking Q&A
    Last Post: 02-12-2013, 09:31 PM
  4. Phase II - Hollowing Rig
    Last Post: 10-11-2010, 06:44 AM
  5. Replies: 0
    Last Post: 03-27-2008, 01:49 AM
