Results 1 to 5 of 5
Thread: color matching
    Apr 2009
    Outside the beltway
    5,260
    color matching
    did you ever have one of those colors you just could not get. I'm working on an existing counter top that is a gray. with about 20 years of ambering of varnish to it. So I stripped it and had a supply shop match it up in lacquer for me, they were so far off. I had some real tweeking to do.
    What is the hardest color you have to match up?
    ::: Andrew Wyeth :::
    colonialrestorationstudio.com
    Flesh tones on a statue.
    Apr 2009
    Outside the beltway
    5,260
    Don are you working with Acrylic paints for touch up's. If so I can help you out. Flesh tones are very easy but takes a good eye and a lot of suttle mixing of color as you go. Little bit of this and a little big of that. As you know flesh tones vary a lot when matching. This painting had a big hole in the right side of the mouth area. I had to repaint about a 2x3" area. This guy was the Chaplin of the Senate in the 40's and 50's, His portrait hangs in the Nation Episcopal church in DC Which he founded.
    Attached Thumbnails Attached Thumbnails IMGA0625.JPG   IMGA0624.JPG   IMGA0612.JPG
    I had a statue that had both arms broken off and after putting them back on I had to touch up the torso to get the color to match, Yes I used acrylics and after a lot of a little of this and a little of that I was so successful that you couldn't tell the repairs had ever been made or that it had been broken, but it took a lot of mixing to get a match
    Apr 2009
    Outside the beltway
    5,260
    That great Don. Flesh tones use to be hard but then I started taking my time and worked at it. The frustration level went way down and the success with way up.
  1. Stain Color vs. Black Diamond Inlay / Color Study
    By Scott R Smith in forum Designs, Plans and Sketches
    Last Post: 11-11-2014, 09:03 PM
  2. Profile matching
    By Steve Southwood in forum Flatwork Project Showcase
    Last Post: 04-27-2013, 03:50 PM
  3. Wood Color and Color Changes
    Last Post: 04-11-2011, 05:27 PM
  4. Two matching hollow vessels.
    By Gari Biasillo in forum Lathe Project Showcase
    Last Post: 10-06-2008, 06:30 AM
  5. matching finishes
    By Gene Miller in forum Finishing School
    Last Post: 01-08-2008, 01:51 AM
