Results 1 to 10 of 12
Thread: Nova Live Center System
    I recently purchased a Nova Live Center System for my Delta model 46-715 lathe and discovered that the knock out rod that comes with the lathe will not remove the live center.
    The hole through the headstock is too narrow to fit the required 1/2" rod that matches the hole in the end of the live center. If I try to plug the end of the live center I then can not knock out the replaceable tips for the center.
    Does anyone have a solution to the problem other than returning the live center?
    Attached Thumbnails Attached Thumbnails Nova1.jpg   Nova2.jpg   Nova3.jpg   Nova4.jpg
    San Antonio, TX
    57
    Live center is mounted on the tailstock...NEVER on the headstock.
    Dario
    http://www.aoturnings.com/
    11,872
    Me too, questions why you even mounted the live center on the headstock. As for the tailstock. Most will remove the live center, or any Morse taper tool, simply by backing the sliding holder as far as possible. (turn counter-clockwise)
    15,811
    So what you are saying is that the hole in your Delta lahte, is smaller than the hole in the live center?
    I guess you need a thinner knock out bar.........?
    That wouldn't work. It would pass through the hole in the live center and only knock out the replaceable tip.
    I recently viewed Alan Lacer's DVD "Woodturning Getting Started Right" and mistakenly thought he suggested using the live center in the headstock.
    I just reviewed the DVD and I stand corrected. When he was suggesting the live center he does say, albeit subtlety, to use it in the tail stock. I just missed it.
    Goodland, Kansas
    4,834
    You are talking about the small drive center Lacer was using. Live Centers are used in the tailstock and drive centers are used in the headstock.
    Bernie W.
    Bernie,
    It all makes sense now. I'm really new to lathe work as you can no doubt discern.
    30,127
    Quote Originally Posted by Rick Levine View Post
    Bernie,
    We've all been at the beginning Rick, so don't hesitate to ask any questions. That what this place is here for.
    15,811
    Rick, like Vaughn says, we have all been there, heck at least you were on the right track.
    When I first got my C-man lathe, I asked if the pointy thing on the end of the lathe without the motor should smoke in use......
    Turns out I had a "Dead" center, which was VERY old school, but that is basically what Alan Lacer is using as a drive center in his videos, I used on the other day, and I like it very much.
  1. A Shopmade Live Center Accessory
    Last Post: 05-07-2014, 08:57 PM
  2. Live Center Adaptor
    By Gord Rock in forum Turning Tool Questions and Show & Tell
    Last Post: 08-15-2009, 08:15 PM
  3. Live Center Question
    Last Post: 02-06-2009, 02:50 AM
  4. Oneway Live Center..........*Got It!!*
    Last Post: 03-15-2008, 03:33 AM
  5. where to find live center inserts?
    By JB Paul in forum Turning Tool Questions and Show & Tell
    Last Post: 12-21-2007, 04:45 PM
