Results 1 to 7 of 7
Thread: 1st Monster attempt
    Aug 2008
    Reno, Nv
    3,632
    1st Monster attempt
    Ok...I know Randy would shoot me, but I had to give it a try. 3x3 walnut that was HUGE learning experience even for 10 minutes. Overall thickness was 3/16. I had to re-true the outside when I mounted it to the chuck. No finish or sanding...just practice. I'm gonna love this!!
    Aside from the part where your inside diameter exceeded the outside diameter, I'd say you're off to a good start. My favorite way of finding boundaries is to step over them once or twice.
    Re-truing a piece after it's reversed isn't too uncommon. I have to do it to some extent on nearly everything. I've learned a few tricks to improve the chances of it being true when reversed, but it's still a pleasant surprise when I reverse a piece and it runs exactly true.
    13,364
    Oct 2010
    Abq, NM
    312
    Jim,
    Hand held, or articulatd arm? I have the mini monster hollowing system and really like the ease of not having to deal with the torque, in the shoulder areas.... Have fun with it. Oh, and thanks for posting......
    Aug 2008
    Reno, Nv
    3,632
    Thanks All!!!
    Michael...same as yours...and maybe as new.
    I really wanted to get a feel for the whole mess, and wow!!!..was that fun!!
    Gotta use it to break it so here we go!!
    Goodland, Kansas
    4,834
    Looks like you've got the hang of it Jim. I told ya you were going to love that thing.
    Bernie W.
    Oct 2010
    Abq, NM
    312
    Jim, there's a little laser thingy on there that if you set it properly it will indicate when you are about "break on thru to the other side"!....if you choose to turn it on!
    I like your style..... we should compare turned kindling piles some time!
    mj
  1. First attempt at piercing
    By Dirk Hoogendoorn in forum Lathe Project Showcase
    Last Post: 02-12-2016, 04:47 PM
  2. Yet Another First Attempt At ...........
    Last Post: 05-31-2010, 10:24 PM
  3. First attempt at ...............
    Last Post: 05-10-2010, 03:30 PM
  4. My first attempt at anything
    Last Post: 09-04-2009, 02:46 AM
  5. And .... attempt #2
    By John Bartley in forum Lathe Project Showcase
    Last Post: 08-20-2007, 09:36 PM
